Tip & How-To about Computers & Internet
Improve net speed.
If you want to tap into this locked speed then make the following changes:
1. Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
Once you have done this click apply and restart your PC.
After rebooting you should see a noticeable improvement in your net speed.
Computers & Internet Logo
how to adjust or can increase internet speed
If you are using Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.
If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you will amaze a noticeable improvement in your net speed. goodluck....
Feb 22, 2011 | Computers & Internet
video buffering
videos like youtube buffer depends on the net speed you are receiving if your isp provides only low speed then it's normal that your videos always buffer and take time to load;;there's a trick to increase your net speed..try this one:
Goodluck!!don't forget to rate!
Feb 21, 2011 | YouTube Videos
how to make youtube videos faster
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks. If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
goodluck!!!
Feb 21, 2011 | Computers & Internet
213 people viewed this tip
David Payne
David Payne
