Tip & How-To about Ovens
Easy Clean of Non-Self Cleaning Ovens
If you don't have the Self-clean feature on your range, here's a tip for a simple way to clean without having to purchase expensive, offensive spray oven cleaners. Using a glass cup, place 1/4 cup of household ammonia in the oven. Let it sit overnight. The next day the ammonia fumes will have loosened the soil
and you should be able to wipe the bottom of the oven with a paper towel and most of the soil will come right out!
PLEASE BE AWARE: If you have a gas oven with a constantly burning pilot, the ammonia will evaporate and be ineffective.
Ovens Logo
do i have to take out the oven racks before I self clean the oven?
If you don't take them out the high heats can wreck the finish on them and turn them all kinds of crazy colors.... but if you don't care what they look like after the cleaning you can let them in...
My recommendation is to not use the self cleaning feature...
Self Cleaning Oven Problem
It is more like a self destruct feature.... it causes many problems with ovens and ranges from the high heat...
heatman101
Apr 21, 2011 | Frigidaire Ovens
owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
The circut breaker on the rear of the stove trips and must be reset every time the oven self cleanui=ing is engaged (Model # PLES399EC). How can this be fixed or prevented?
The best thing to do is not use your self cleaning feature....
Whoever invented that has caused way more problems then it solved...
It is a featured designed pruely to sell product because people are inherently lazy and because it burns up good products and then they get to sell more...
heatman101
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet of the range you can smell the odor.
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 15, 2010 | Ovens
1,271 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
