Tip & How-To about Garden
Seasonal equipment storage.
Every winter when the grass stops growing and we walk away from our lawnmowers, weedeaters, edgers, blowers, ect. we tend to complain when they will not start when it's time to start using them again. A simple little tip that will help this problem is to treat your fuel through out the season. Your only other option would be to turn the fuel off and run the fuel out of the carburator until the engine dies. Then drain the fuel out of the tank. When it comes time to use your equipment again, it will start because it has fresh fuel.......and you won't be complaining. This would also be a good time to change your oil, grease your unit, clean/change your air filters, fuel filters, ect. sharpen or change your blades, replace worn belts, ect. When it comes time to use them again, you will be glad you did.
Garden Logo
lawnmower problems
if you let grass grow to long will be to heavy to be picked up and go into bag
Aug 13, 2014 | Garden
lawnmower using twice as much gas as last year, why?
plain were and tear on these little motors will do it could be your grass is growing faster
Jun 11, 2012 | Briggs & Stratton Briggs Stratton...
won't start after replacing the plug. there is fuel.
get another plug theres a lot of bad small engine plugs on the market that are no good right out of the box! i run into 15 last summer working on weedeaters and chain saws and lawnmowers
Jan 15, 2010 | Homelite 'Yard Broom' Leaf Blower
186 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
