Tip & How-To about Garden
TORO S200 CARBURETOR REBUILD
Hello sir, well the old s 200 s620 will not run, ok here we go,,go to the repair shop and buy a carb, kit for the s 200,s620,in that kit you will get a diaphragm,gasket,inlet needle and seat and a round gasket,get a can of carb,cleaner at auto zone,when you get home here is what you have to do, put machine on a work table,remove fuel cap and drain the fuel,remove the top cover, pull the rope out and clamp to where it will not go back in,remove the four screws in bottom cover,pull cover out slightly to pull off vacuum hose,remove choke cable from carb,.now remove the bottom cover and let it hang down on floor,tilt machine up to where you are looking at carb,now remove the four screws on the bottom of carb,remove the cover,if the gasket stays on the carb,you are going to have to peal it off the same if it sticks to the cover,,""be sure and make note to which way the diaphragm and gasket are on,because that have to go back on the same way""remove the inlet needle and seat with a 9/32 socket,be care full not to strip the head,make sure the gasket and spring come out also,before you remove the one or two adjustment screws on side of carb,high and low turn in and count the turns thay will have to be set the same way when put back in and mark which one is which i use a card and mark hi and lo stick on card, now you are ready to clean the carb,using a small wire brush set from harbor freight, spray cleaner in and on the carb and clean with brush until clean,making sure to get the fuel inlet and middle of the carb, the bottom plate should be cleaned also,now to put back together,put in the new inlet needle and seat don't over tighten,put the plate and gasket and diaphragm on and the four screws,put fuel line on,oh it is a good ideal to blow out the fuel line and tank if you have air,install bottom cover hooking up the vacuum and choke,put the screws in cover,it is a good ideal to buy a new spark plug also,RJ18Y,,put fresh mixed fuel in,i mean fresh from the pump and mixed,prime and start, you may have to adjust the carb,a little to get max speed, oh you could get a book on the s200 at the shop,hope this helps,any comment welcome,thank you. and here is the manual
692508.pdf (application/pdf Object)
Garden Logo
will not start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 18, 2012 | Cub Cadet Garden
how dose the carboretor work
Feb 10, 2012 | Garden
I have a Toro S620 snow blower, I push the primer bulb and it starts right up then dies. If I keep pushing the primer bulb continualy it will keep running but the moment I quit it dies.
The carburetor bowl needs to be taken off and most likely the float and needle need replacing. When you prime the carb, this is shooting gas straight to the carb instead of traveling though the jets. This is a very easy task, but I know if you're using a snow blower you need it quick. The kit is about $5 and be sure to take your machines info with you.
Dec 30, 2010 | Toro Snow Blower Scraper For S200 s620 New...
I want to rebuild the carbs.
Hello. Honda has a rebuild kit specifically for your bike. Contact your local Honda dealer to purchase one. Joe
Mar 31, 2010 | 2005 Honda CB 750
Hello, I have a Toro snowblower Model ccr 2450. The starter runs but does not engage to start the engine. Can you tell me how to fix this problem without taking it to a repair shop?
Remove the starter, then check the teeth, if the teeth
are ok, then the throwout Bering is bad, this is the part than pushes out the teeth so it contacts the
flywheel. The parts you need, teeth ,spring, throwout,
show as a kit, but you must buy them from a toro dealer, You need to have your serial #, because the parts are listed by different serial #'s. Now most times you would have to buy the whole starter, but it looks like you can get the kit. If the teeth are bad then the throwout is ok, but you still need the kit to fix your problem.
Feb 14, 2010 | Garden
1,801 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
