Tip & How-To about KitchenAid K45SS Classic Stand Mixer
KitchenAid mixer not running or needs new brushes.
If you run your KitchenAid mixer long enough it will need new brushes. Symtoms would be eradic running, runs slow (no additional noise) or a smell of sulfur when running.
If your unit has any of these symtoms you should change the brushes. Brushes are available at http://www.appliancepartspros.com/Appliance-Parts/Kitchen-Aid-Mixer-Parts/index.aspx . They cost $3.55 each and you will need two.
First remove the screws holding in the brushes and remove the brushes.
The brushes have one corner which is shaved off at a 45 degree angle. Make a note of which direction it is facing as this is how the new brushes must be orientated in order to seat properly.
The brushes are located on opposite sides of the main mixer body under a black cover plate with a slot. Remove the cover while holding onto it as it is spring loaded. Remove the brush. Do the other side also.
Remove two screws from the rear of the unit holding the cover between the two halves of the unit (top and bottom). You will need to remove all the screws on the underside of the unit. There should be four total.
Next you will have to remove the power beater driver located at the front of the unit.The shaft located vertically has a pin in it which needs to be driven out with a punch and hammer. Then a "C" clip must be removed from the shaft. Use a "C" clip plier available at any automotive parts store. Place the ends in the holes in the tips of the "C" clip and squeeze. This will release the pressure on the shaft and allow the clip to be removed.
Next pry the bezel off around the exterior of the plate which will expose about 6 screws which need to be taken out. When all the screws are removed you can remove the head assembly as well as the top of the unit exposing the motor armature. The armature will be the blackened, segmented part of the armature directly under the brushes.
At this point you should be able to see how burnt the armature is. Using crocus cloth (available at Lowes or Home Depot) clean the armature until it shines. Do not sand it any more than necessary or sand flat spots in it. A light contact is all that is needed.
Clean the armature with any good electronics parts cleaner, available at Lowes or Home Depot, to get rid of any filings. Clean up any filings or dirt in the unit.
Relubricate The gear box with light grease if necessary. Reassemble the unit and install the new brushes. The brushes will only go in one way and work. If inserted wrong, the unit will not run. The brushes must be seated on the armature.
During the assembly process remember to use Lock Tite on all screws to avoid future problems.
Thanks for using FixYa and for the great rating.
hardrocko
KitchenAid K45SS Classic Stand Mixer Logo
kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
What are black screws on the side of the mixer
Those are the two Motor carbon Brushes. Without them, the motor
would not run at all. Sooner or later, they will become so worn out
that the mixer will stop running. And when it does, don't be alarmed.
You simply purchase new ones for it. To see what they look like,
Go on Ebay & search for Kitchenaid Motor Brush*. They are keyed so
there is only one proper way to insert them into the motor housing.
If either or both brushes do not make contact with the motor coils,
the motor will not run.
Jul 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Runs slow and makes a clacking noise I thing that it needs oiling after 20+ years of use. I have it detached from the stand, but cannot get it to open up to dust it out and oil the moving parts. Any advise?
It sounds like the brushes are worn out. The sound you hear could be the brush holders making contact with the commutator or it could be a broken brush. Also check gears for wear. Here is a website that has diagrams and parts. Hope this helps.
kellysappliance.net/mixer.aspx
Aug 17, 2009 | KitchenAid Food Mixers
mixer turns sometimes
The smell is the motor overheating and intermittant run is worn brushes in the motor
Jul 04, 2009 | KitchenAid K45SS Classic Stand Mixer
2,666 people viewed this tip
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
