Tip & How-To about KitchenAid K45SS Classic Stand Mixer
KitchenAid mixer making grinding sounds.
Is your KitchenAid mixer making loud grinding sounds and running slow? This is a common problem with these mixers. One or more of the screws holding the beater drive mounting plate in, has backed out, and is rubbing against the plate making a loud grinding sound and slowing the unit down.
The solution involves removing the beater driver shaft and plate and taking out all the mounting screws, then reinserting them with lock tite, available at Lowes or Home Depot in the hardware department.
The beater shaft, located vertically, has a pin in it which needs to be driven out with a punch and hammer. Then a "C" clip must be removed from the base of the shaft. You will need some "C" clip pliers available at any automotive parts store. Using the pliers insert them in the holes in the "C" clip ends and squeeze the handle. This will spread the "C" clip and allow you to slide it off the shaft.
Next pry the chrome bezel off around the exterior of the shaft which will expose about 6 screws which need to be taken out. These are the screws causing the problem. They should be removed one at a time and replaced with lock tite added to the threads.
Reassemble the mixer after all the screws have had lock tite added. This should quiet your unit and make it run faster.
Thanks for using FixYa and for the great rating.
hardrocko
KitchenAid K45SS Classic Stand Mixer Logo
on low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
kitchenaid 250 watts k4ss mixer
The repair manual says that the mixer can make this grinding sound at slow speed, like stir or 2. This is normal, especially until it warms up. This is the sound of the gears turning at slow speed.
Dec 13, 2007 | KitchenAid K45SS Classic Stand Mixer
the kitchenaid is making noise and moving
Sounds like the hinge pin may have slid out of half of the base..
Nov 25, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
2,617 people viewed this tip
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
