Tip & How-To about Computers & Internet
How to convert analog video to digital format.
Equipment needed
  1. PC
  2. Analog Capture Card (you can find prices here)
  3. Sound card (some capture cards has their own audio input)
  4. Cables
  5. VHS Player/Camcorder
  6. Capture Software (Windows Movie Maker 2 can do this)
Steps to perform
  1. Hook up your capture device to your computer
  2. Turn on your PC, install the drivers
  3. Hook up your analog player to your capture card with the cables
  4. Load your capture software
  5. Set the capture options (video and audio)
  6. Start the capture process
  7. Start the playback on your analog device
  8. Once the analog device has finished, press stop
  9. Stop the capture process
  10. Save the video
Remember, you capture card merely records the signals that comes from you analog device. If the footage is blurry and choppy, it's probably because of aged tapes or dirty video heads.
Computers & Internet Logo
how do i download my pictures from my handycam trv49e so that my tapes can be reused
Search Google and found this:
The Sony CCD-TRV49 camcorder doesn't have a digital output, so you have to capture and convert the analog composite video signal and audio signals. On the PC side you need an analog video capture board, a sound card to capture the audio and a video capture/editing software. You can also find on the market external USB devices that contains all these things.
The composite video is the yellow RCA connector that goes straight to your capture board.
The left audio is the white RCA connector and the right audio is the red RCA connector. These are mixed on a stereo jack plug that enters into soundcard input socket.
Source(s):http://www.allpinouts.org - Open Reference Archive for Connectors, Cables and Adapters Pinouts.
Jul 09, 2012 | Sony Handycam CCD-TRV49E Camcorder
How to conver analog vedio to digital
you need following Equipment
  1. PC
  4. Cables
and perform these Steps
  10. Save the video
Good luck, do rate the solution if helped
Nov 30, 2010 | Televison & Video
HOW T DO I CONECT A VHS VIDEO RECORDER TO MY WINFAST TV 2000XP EXPET TV CAPTURE CARD ?
Your VHS recorder has a Coaxe output! So does your card the sound will be replicated there as well, now it would not hurt to get a capture card that has those plugs as you rendering would be much more prestine. Pluag you VHS into the coaxe input on your card set the channel to 3 and you got it bud!!!
Rulds2008
May 25, 2009 | Leadtek WinFast TV 2000 XP Expert...
Sound is not recorded
The problem would appear to be your audio settings.
You have the audio input set to Realtek HD Audio Input. That is the audio input on your soundcard, not the video capture card. You will need to change this so that you have the capture card selected. (I am not familiar with this exact model of card so I can't tell you exactly what it will be called.)
Alternatively, if you are trying to capture the audio via your soundcard (not recommended as it can cause sync problems) you will need to make sure that the 'line in' channel in enabled in the Windows mixer:
Start>Control Panel>Sounds & Audio Devices>Audio Tab>Click Volume in sound recording section>Tick Line In
Hope this helps,
Matt
Mar 06, 2008 | KWorld V-Stream Xpert VS-L883D...
s-video on pc
the audio gets plugged into the sound card (or on-board sound system) audio input jack.
Aug 05, 2007 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
364 people viewed this tip
David Payne
David Payne
