Tip & How-To about Electronics - Others
How to restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
  9. Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
  10. Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  11. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
  12. Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  13. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Electronics - Others Logo
How do i restore my ipod
How to restore iPod
  6. Click Restore.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Feb 10, 2015 | Audio Players & Recorders
ipod is disabled and cannot connect to itunes as have new laptop
How to restore iPod
  6. Click Restore.
Apr 02, 2011 | Apple iPod touch
how do i reset ipod nano 2G, I am getting nothing
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software
may need to be downloaded to your computer.
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that
came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes.
3) Select your iPod in the Source panel and you will see information about your iPod appear in the
Summary tab of the main iTunes windows.
4) Click the Restore button. You will be prompted with one or more restore options that may prompt
iTunes to automatically download the latest iPod Software. Use restore option 4.
Apr 14, 2010 | Apple iPod nano
how do i restor my ipod?
ipod shuffle
You should do a restore:
How to restore iPod shuffle
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect iPod shuffle to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod shuffle in the Source pane and you will see information about it appear in the Settings tab of the main iTunes windows
  6. The Version section tells you whether iPod shuffle is up to date or needs a newer version of the software.
  7. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  8. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  9. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present a message instructing you to leave iPod shuffle connected to computer to complete restore process.
  10. During the stage 2 of the restore process, a green LED will flash once on iPod shuffle, then amber and green LEDs will flash briefly, and finally the amber LED will begin to flash continuously. It is critical that the iPod shuffle remains connected to the computer during this stage.
  11. After stage 2 of the restore process is complete, the iPod Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dec 29, 2007 | Apple iPod shuffle MP3 Player
895 people viewed this tip
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
