Tip & How-To about Computers & Internet
How to save Word as PDF
Many people have to deal with PDF format every day. Business professionals, knowledge workers or even students, they need to create PDF file for some reasons but since Adobe Acrobat will cost thousands of dollars, knowing how to save word as PDF is veryusl in our daily work..
How can you save Word as PDF? There are several methods for you. It depends on which Word version you are using.
Using Word 2007 Add-in
If you are using Microsoft Office 2007, you can download the add-in.The plug-in will automatically add the Save as PDF function into your Office 2007 programs. So that saves the documents directly to PDF Format.
Click on the Office icon on the top left corner, then click "Save As" on the drop down menu and then select "PDF". The Word document will be saved as PDF.
Using free Online Conversion
If you are using Microsoft Office 2003, you can use free online conversion.Google a free online conversion and choose a good one
Click ' Browse' and select the file on your computer, Click 'Convert to PDF' and wait for it to process. And then you can open it in PDF format. Some free online conversion require you provides Email so that they can email the pdf file to you after conversion.
Using Desktop Word To PDF Converter
Although online Word to PDF Converter is easy to use and most are free. But when we nee to convert confidential files or your own works, due to privacy, we cannot trust online converter.Also if you want to convert large files, online conversion may results failure. So the best way is uing a desktop PDF Converter like Advanced Word To PDF 5.0 which provides you a safe and professional method to convert Word to PDF quickly.
The conversion quality of PDF to Word Converter is fairly good, all the original text content, page layouts, images,and text hyperlinks preserved after conversion.It allow you convert large file at the same time.
What is more, The PDF files created by Advanced Word to PDF are protected with strong 128bit encryption. Therefore, your PDF documents could be protected by Owner Password, User Password and more advanced features to against from copying text and images, modification to document and comments, printing document, etc.
Download the program and install it. And then add your files to convert. Of course you can Specify output folder like location and Advanced Option such as add password , copy,edit limitation etc.
The process is easy and takes a few minutes even you are converting large files.
The three method post above shows you how to save word as PDF , you may have your own choice when you need to convert word to PDF files.
Computers & Internet Logo
download Microsoft Office 2007 Professional
hi
go to google site type msoffice 2007 you will able to download msoffice
Jul 21, 2010 | Microsoft Office Professional 2007 Full...
How to download microsoft powerpoint 2007
Free version is the Powerpoint Viewer 2007 download link this HERE totally free to view PPT files only.
Full version of Powerpoint 2007 is included in the Office 2007 Bundle free for 60 day check it out HERE if you are an NHS worker you can get it for a very low price of only £8.95 valid e-mail is required.
If you are a student there is a 90% discount HERE it will cost you £38.95
Jan 05, 2010 | Microsoft Office Professional 2007 Full...
the program crashes every time I try to create pdf from a scanner. It worked fine before
Have you tried creating a pdf from a file to eliminate the an Acrobat problem?
If you can create a pdf from a file, then you may need to reload your scanner software.
Oct 21, 2009 | Adobe Computers & Internet
unable to create pfd with word 2007 document
That is normal, Word 2007 cannot create PDF documents, it can only save files on PDF but, being PDF non his own format, it will lose document format, and may not display pdf.
To create PDF you need the full version (not the free acrobat reader) of adobe acrobat, or a different adobe software (eg illustrator) that manages PDF.
See
Adobe Acrobat - How To Create Accessible Adobe® PDF Files Booklet
How to Create PDF Files
Jan 03, 2009 | Microsoft Office Professional 2007 Full...
I cant export a pdf from quarkxpress 6.0 Have tried everything. Its telling me to go to postscript printer??? I have made a postscribt and it does nothing. HELP
you need Adobe Acrobat Professional or Adobe Indesign in order to export or convert your documents to PDF format. There are several ways to do it, you can even use Adobe PDF printer and create PDF versions of anything you print.
Dec 29, 2008 | Computers & Internet
233 people viewed this tip
David Payne
David Payne
