Tip & How-To about Apple iPhone Smartphone
How to unlock iPhone using PwnageTool or redsn0w + ultrasn0w combination
This will guide you on activating, jailbreaking and unlocking your iDevice & thus will be of 2 parts: Part 1 - Jailbreak with redsn0w; & Part 2 Unlocking with ultrasn0w.
Hardware compatibility:
  1. UNTETHERED JAILBREAK - iOS 4.2.1, 4.1, 4.0.2, 4.0.1 and 4.0
    • iPhone 3G
    • iPhone 3GS old bootrom
    • iPod touch 2G non-MC model
  2. TETHERED JAILBREAK (?) - iOS 4.2.1 ONLY - you can use either greenpois0n or sn0wbreeze for untethered jailbreak, for these iDevices:
    • iPhone 3GS new bootrom
    • iPhone 4
    • iPod touch 2G MC model
    • iPod touch 3G
    • iPod touch 4G
    • iPad
  3. UNLOCK - iOS 3.0 up to 4.2.1
    • iPhone 3G
  4. UNLOCK - iOS 3.0 up to 4.0.2 ONLY
    • iPhone 4
Not sure if your iPhone 3GS has old or new bootrom? CLICK HERE. Or if your iPod touch is MC or non-MC? CLICK HERE.
Compatible basebands (BB) for ultrasn0w 1.2.2:
  • 06.15.00 - iOS 3.2.2 from iPad (read further for details)
  • 05.13.04 / 01.59.00 - iOS 4.0.2, 4.0.1 & 4.0
  • 05.12.01 - iOS 3.1.3
  • 05.11.07 - iOS 3.1 & 3.1.2
  • 04.26.08 - iOS 3.0
Notice that BB 05.14.02 & 05.15.04 are NOT part of the list. You need to update these BB to 06.15.00 for ultrasn0w unlock to work. Read further for more info.
However, if your BB is 05.13.04 or lower, you can proceed with jailbreaking but make sure you DO NOT INSTALL THE IPAD BASEBAND.
WARNING: Read the following consequences of updating BB to 06.15.00:
  1. There is no way to come back down from 06.15, & there's no hiding the baseband version from Apple. You'll be voiding your warranty in a very obvious way.
  2. If some future baseband comes out with a critical fix, you won't be able to update to it if it remains down in the 05.xx sequence (then again, you wouldn't update to it if you wanted to keep your unlock anyway).
  3. Starting with FW 4.2.1 if you have 06.15 on your iPhone you won't ever be able to restore to stock firmware (it will fail). You'll need to only restore to custom IPSWs (then again, if you're unlocker you should already be doing that).
DO NOT PROCEED if you don't agree.
What you need: NOTE: Download iPad's 3.2.2 IPSW ONLY if you'll use PwnageTool. Also, download ONLY the IPSW for your current iOS version. CLICK HERE if you have no idea what version is installed on your iDevice, especially if it's currently disabled.
For jailbreaking other iOS versions like 4.3.2, use other versions of redsn0w. CLICK HERE to see the list of all redsn0w versions.
Procedures:
PART 1 - JAILBREAKING with redsn0w (all iDevices):
  1. Connect your iDevice to the computer, run redsn0w & click Browse
  2. Locate IPSW for your current iOS, select it & click Open
  3. Wait until it say IPSW successfully identified. Click Next
  4. If you plan to unlock your iPhone 3G / 3GS old bootrom, you need to check Install iPad baseband to update BB to 06.15.00 Click Yes if you're OK with these consequences:Again, you only need this option if your BB is either 05.14.02 or 05.15.04. This will result to updating your BB to 06.15.00 which can be unlocked using ultrasn0w. Also, if your BB is 05.13.04 or lower, this jailbreak will still work for your iPhone but make sure you DO NOT INSTALL THE IPAD BB! You don't need it! For iPod touch users, the BB thing does not apply for you. so you have nothing to worry about.
  5. Choose some more options before you click Next
  6. Turn OFF your iDevice & prepare to put it to DFU mode then click Next
  7. DFU mode: Press & hold the POWER button for 3 seconds
  8. DFU mode: Press & hold HOME button while still holding on the POWER button for 10sec
  9. DFU mode: Release the POWER button but keep holding on the HOME button for another 15 seconds or until you see Jailbreaking... on redsn0w
  10. Wait until it tells you that The rest of the process takes place on your iDevice. Click Finish That will take around 8 to 9 minutes to complete
Once the jailbreak is done, open your iDevice & you'll find Cydia on the 2nd page of your homescreen.
Watch this video:
PART 2 - UNLOCKING with ultrasn0w (iPhone ONLY):
  1. Open CydiaDon't worry if Cydia's icon is blank/all-white, it will still work. The first time you open Cydia, this is what you'll see (image below), then it will close itself and take you back to the homescreen
  2. Open Cydia again. Before you proceed with the unlock, go to Changes first and do a Complete Upgrade
  3. Tap Reboot Device after the upgrade
  4. After reboot, you can then unlock. Open Cydia again (for the third time), and tap the following (in sequence):
    • Manage
    • Sources
    • repo666.ultrasn0w.com
    • ulrasn0w
  5. Tap Install, then tap Confirm
  6. And finally, tap Reboot Device
And you're all done! Your iPhone should catch signal after the reboot.
If you want to see some screenshots on installing ultrasn0w, CLICK HERE.
For untethered jailbreak for all iDevices with iOS 4.1, CLICK HERE.
Credits:
iPhone Dev Team for redsn0w & ultrasn0w
kidantvideos
Please rate if this helped you:
Apple iPhone Smartphone Logo
how to jailbreak iOS 5.1 using redsn0w on PC
Well, if you are willing to perform iPhone jailbreak in a more simple yet time-saving manner, follow the step by step guide from this website: automaticiphoneunlocker.com
You may unlock any iPhone including 2G, 3G, 3GS, 4 and 4S models. This includes both the older and latest versions under 5.1.1.
Enjoy more freedom with your iPhone!
May 05, 2012 | Apple iPhone Smartphone
HOW CAN I JAILBREAK MY IPOD TOUCH?
by using jailbreaking software
Mar 21, 2011 | Apple iPod touch
Is 4.3 available for untethered jailbreak?
No not as of yet, but 4.2.1 is available, there is a tethered jailbreak, give it a couple of days. Check redmondpie.com has all the updates.
Mar 14, 2011 | Apple iPhone Smartphone
how can i unlock and jailbreak iphone 3Gs with 3.1.3 ? i didnt update the software yet im still on 3.1.2 n blackrain
Yes, you can. And if you are willing to perform iPhone jailbreak in a more simple yet time-saving manner, follow the step by step guide from this website: automaticiphoneunlocker.com
You may unlock any iPhone including 2G, 3G, 3GS, 4 and 4S models. This includes both the older and latest versions under 5.1.1. Enjoy more freedom with your iPhone!
Best
Mar 14, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
3,559 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
