Tip & How-To about Office Equipment & Supplies
Paper Out
Symptoms:
There is paper but printer insists otherwise.
Precautions:
Please note that all procedure(s) mentioned here are to be done while printer is off and don't forget that laser printers use heat so be careful while touching printer objects.
For any reason, if you're hands are contaminated with ink or toner, clean them well.
Action:
Clean paper sensor(s) by blowing some air from a pressurised source.
If this action didn't work for you, perhaps there is a damaged sensor and its time to contact service.
Good luck and happy printing.
say i have a paper jam but dont see any paper and i dont know where the print carriage door is located to check it
Usually it was at the back of your printer, but you still have to consider the printer manual for the right procedure on how to open the carriage and remove the paper in a right way otherwise you could have done a serious prblem with your printer.
May 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
printer will not print and insists that there is a paper jam but there is no paper jam...there was but I cleared it ..how can I fix this?
You did not _completely_ clear it -- the sensors that detect a jam are still detecting a jam.
Turn the printer off.
Turn the printer on, and see if it still reports the problem.
Otherwise, take the printer to a qualified technician.
Nov 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
183 people viewed this tip
jasbo
jasbo
