Tip & How-To about JVC KD-AVX33 Car Video Player
Another way to bypass park break check
While installing stereo just connect e-brake wire directly to ignition wire (as far as I remember - yellow wire in standard ISO connector) So it is some cheat - stereo will think, that you are always using parking breaks. Do not forget about your safety :)
JVC KD-AVX33 Car Video Player Logo
constant power supply
next time by the wire harness that plugs it into the factory wire plugs never cut the factory plugs off you have wired something wrong you may damage something or start your truck on fire.
Apr 04, 2010 | Alpine CDE-9845 CD Player
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1995 Honda Civic This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line. The wires listed are the ones you will need to successfully complete the task. Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors. The following FixYa TIP is good for all Honda Civics for the following production years: 1995 STEREO WIRING COLOR CHART: Constant 12V+: Blue/White Switched 12V+: Yellow/Red Ground: Black Illumination: Red/Black Dimmer: n/a Antenna: Driver's Pillar Front Speakers: Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers: Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White NOTES: - none - Additional Accessories: Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 70-1720 Metra Brand Antenna Adapter: n/a ALARM / REMOTE START WIRING CHART: Constant 12V+: White - Ignition Switch Harness Starter: Black/White - Ignition Switch Harness Ignition: Black/Yellow - Ignition Switch Harness Accessory: Yellow - Ignition Switch Harness Tach: Blue - Distributor Brake Switch: Green/White - Brake Switch Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector) Parking Lights: Red/Black - (+) Above Fuse Panel Head Lamp: Red/White - Steering Column Hood Pin: n/a Door Trigger: Light Green/Red - (-) Driver's Running board Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module Horn: Blue - Steering Column (Relay Required) Windows UP: LF=Red/Blue RF=Blue/Yellow Windows DOWM: LF=Red/Yellow RF=Blue/Green NOTES: - none - CRUISE CONTROL: Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake Switched 12V+: Black/Yellow - Ignition Switch Harness Ground: Use Chassis Near Cruise Control Module Hot Side of Brake: n/a - Brake Switch Cold Side of Brake: Green/White - Brake Switch Tach: Blue - Distributor VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector. NOTES: 4000PPM Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
Apr 03, 2010 | Honda Civic Cars & Trucks
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1994 Honda Civic This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line. The wires listed are the ones you will need to successfully complete the task. Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors. The following FixYa TIP is good for all Honda Civics for the following production years: 1994 STEREO WIRING COLOR CHART: Constant 12V+: Blue/White Switched 12V+: Yellow/Red Ground: Black Illumination: Red/Black Dimmer: n/a Antenna: Driver's Pillar Front Speakers: Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers: Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White NOTES: - none - Additional Accessories: Metra Brand Dash Kit: n/a Metra Brand Wiring Harness: 70-1720 Metra Brand Antenna Adapter: n/a ALARM / REMOTE START WIRING CHART: Constant 12V+: White - Ignition Switch Harness Starter: Black/White - Ignition Switch Harness Ignition: Black/Yellow - Ignition Switch Harness Accessory: Yellow - Ignition Switch Harness Tach: Blue - Distributor Brake Switch: Green/White - Brake Switch Trunk Pin: Green/Black - (-) Above Fuse Panel (Blue Connector) Parking Lights: Red/Black - (+) Above Fuse Panel Head Lamp: Red/White - Steering Column Hood Pin: n/a Door Trigger: Light Green/Red - (-) Driver's Running board Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box Door Unlock: Green/Red - (-) Driver's Door at Door Lock Module Horn: Blue - Steering Column (Relay Required) Windows UP: LF=Red/Blue RF=Blue/Yellow Windows DOWM: LF=Red/Yellow RF=Blue/Green NOTES: - none - CRUISE CONTROL: Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake Switched 12V+: Black/Yellow - Ignition Switch Harness Ground: Use Chassis Near Cruise Control Module Hot Side of Brake: n/a - Brake Switch Cold Side of Brake: Green/White - Brake Switch Tach: Blue - Distributor VSS Wire : Yellow/Blue - Driver's Side Dash Footwell, Grey connector. NOTES: 4000PPM Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil. Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
Apr 01, 2010 | Honda Civic Cars & Trucks
Car wiring for stereo
Go to halfords or somwher like that buy the iso connector for your make and model
if your car still has the ford plugs on the ends of the wires just plug in the connector between car and stereo If the ford plugs are missing cut the ford end off the connector match the wires to your car and solder together and plug into your stereo or any others you buy in the future with an ISO connection Did this with my 89 orion.
Dec 08, 2008 | 1989 Ford Escort
car radio not saving stations but have used car loom from skoda to roadstar head unit ,so iso plugs go straight in and eveything works but take out keys stations are lost and cd,s not remembering where they last were stopped. help ||||||
My dear friend all the stereos got a two cables to feed the stereo the red put on the ignition wire and the yellow on a direct source to the battery positive lead maybe you don´t put the yellow one correctly.Good luck
Aug 25, 2008 | Audio Players & Recorders
954 people viewed this tip
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
