Tip & How-To about SanDisk Sansa c240 MP3 Player
Part I: How do I add or delete files, copy from CD to my Mp3 Player with Windows Media Player?
How do I use Windows Media Player? A Help Guide
By Tha Mp3 Doctor
There have been a ton of questions on how to use Windows Media Player in the Fixya forums. This article also covers the often-asked question: “How Do I Add Songs to My Mp3 Player?,” “How do I transfer songs to my Mp3 player?,” “How do I delete songs from my Mp3 player?,” and “How do I get songs from Cd’s onto my Mp3 player?”
First, a note – not all Mp3 players work with Windows Media Player – it is best to check with your mp3 player’s user manual – these manuals are usually available from the manufacturers’ websites - to make sure they don’t have any other software recommendations for you. Some mp3 players have their own proprietary software for transferring/deleting songs. Nonetheless, more and more Mp3 players work with Windows Media Player – probably 80%, at least.
Second, there are many versions of Windows Media Player out there. A few older Mp3 players still work with Windows Media Player 9. Most work with Windows Media Player 10 or 11 only. If your mp3 player user’s manual only suggests using Windows Media Player 9 or 10, you may experience problems when connecting your Mp3 player to a computer operating Windows Media Player 11 – some mp3 model #’s have a firmware upgrade which eliminates the bad effects of using Windows Media Player 11 in these circumstances. Other model #’s do not have such a fix, and will cause you problems – check the manufacturers’ warnings on their websites. Philips makes some mp3 players that work with Windows Media Player 11 and some that do not, for instance. The model # is more important than the manufacturer name in these cases.
For instructions on rolling back to an earlier version of Windows Media Player, go to:
http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx?info=EXLINK#RollingbacktoapreviousversionofthePlayer
I have switched from ver. 11, back to 9, forward to 10, forward to 11, back to 10, and forward to 11 all without incident, and without losing a single music, picture or video file – just in case you are worried about the prospect.
SanDisk Sansa c240 MP3 Player Logo
music loading
Websites change all the time, but this should help:
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
-Tha Mp3 Doctor
Nov 25, 2008 | SanDisk Sansa Clip MP3 Player
GPX MW3847 MP3 QUESTION
Uninstall all GPX software first. Try Windows Media Player again. If Windws Media still crashes, uninstall then reinstall Windows Media Player.
-Tha Mp3 Doctor
Sep 04, 2008 | GPX MW3836 MP3 Player
Windows Vista problem with RCA TH1101 MP3 Player
This link should have the firmware upgrade that you need - if you correct the firmware upgrade link and not some other link, then it will not prompt you to do anything with Windows Media Player 11.
http://support.rcaaudiovideo.com/downloads.aspx?product=25
-Tha Mp3 Doctor
May 11, 2008 | RCA TH1101 MP3 Player
LOADING QUICK START FOR A MP3 PLAYER
Amy - check to make sure you have a compatible version of windows
Is your version of Windows earlier than Windows 2000/SP3? If so, the software will not run.
Are you running Windows Vista? If so, refer to RCA's website for making software compatible at:
http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=
1214&p_created=1201207999&p_sid=TLT3Gy4j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTUwOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9zY2ZfYnJhbmQ9JnBfcGFnZT0x&p_li=&p_topview=1
-Tha Mp3 Doctor
Guest - restate the question
ebony - go to http://www.rcaaudiovideo.com/product.aspx?product=27&post=6 for the software/manuals
guest - 3 possibilities - 1) all the songs would be erased, 2) the player might work better, or 3) it might work worse
-Tha Mp3 Doctor
Feb 28, 2008 | RCA TH1101 MP3 Player
philips gogear
Windows Media Player to transfer files
Arcsoft Media Converter to convert video files into a format the player will recognize
They both come on the installation CD for the GoGear
-Tha Mp3 Doctor
Jan 08, 2008 | Philips GoGear HDD075/17 MP3 Player
1,848 people viewed this tip
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
