Tip & How-To about Computers & Internet
How to lock router so no one can steal internet
1.) Consult your manual or contact your router manufacturer for help in logging into your router.
2.) Set up an encryption key (WEP is pretty popular). You can consult your manual or the manufacturer for help in this as well as the process differs from router to router.
3.) On your devices, input that WEP key when connecting so that you can actually use the thing.
4.) Enjoy your own, safe, secure, encrypted wireless network!
Computers & Internet Logo
51331 unable to connect to the internet
1. Check Nintendo's router info for special notes, if available, for your router.
  • Click here to go to our Wireless Router Configuration page.
  • Use the drop-down box on the left to select, if available, your router manufacturer.
  • Click on your router's model number, if available.
  • Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
2. Are you using WEP security on your router?
  • Log into the router using the default IP (consult your router's manual for assistance)
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (1-9, AF, no other special characters or letters).
  • Verify they are using the WEP Key in the first (# 1) slot. Even though their router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot # 1.
3. Check to see if your router is using MAC filtering.
  • Log into the router using the default IP.
  • Find the section for MAC Filtering (typically under "Security").
  • If MAC Filtering is on ( "enabled"), enter the Nintendo DS's MAC address to the list of approved MAC address. For info on locating the DS's MAC address, click here. (For assistance with locating the MAC Filtering section of your router's setup tool, please consult the router's manual or contact the manufacturer.)
Jan 14, 2011 | Nintendo Wii Console
cant connect my DS XL to inter net
51300-51398 is typically caused by WEP Key issues. Please read the following information:
Jan 13, 2011 | Nintendo DSi XL Burgundy
whene i try to go on line with my dsi this is what i get do you know what this mean error code: 051300-1
This error message is typically caused by WEP Key issues. Please read the following information:
Jan 04, 2011 | Nintendo DSi Blue Console
error code 051310
Here is the info that may help you...
Error Code: 051310
Our experience has shown that this error message is typically caused by WEP Key issues. Please read the following information:
* Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
* Are you using WEP security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
3. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
4. The WEP Key must be a Hexadecimal (1-9, A-F, no other special characters or letters).
5. Verify they are using the WEP Key in the first (#1) slot. Even though their router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot #1.
* Check to see if your router is using MAC filtering.
1. Log into the router using the default IP.
2. Find the section for MAC Filtering (typically under "Security").
3. If MAC Filtering is on ("enabled"), enter the Nintendo DS?s MAC address to the list of approved MAC address. For info on locating the DS?s MAC address, click here.
For instructions on how to find the MAC address for Nintendo DSi, click here.
* Nintendo DS / DS Lite only:Check to see if your router is set to "g only" mode. In order to work with the Nintendo DS, the router must be set to "mixed" or "b and g".
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Jan 01, 2011 | Nintendo DSi Black Console
i need to lock it up,, some one is stealing from me i had 26 dollors extra charges
1.) log on to your router.
Nov 24, 2010 | Arris WR850G Router (DHWR850G)
598 people viewed this tip
David Payne
David Payne
