Tip & How-To about Cell Phones
How to format a HTC desire
Warning : the following will erase everything on your phone, your settings, your data, etc!
The most convenient way to do a factory reset is via the phone settings.
  1. From the Home screen, press MENU and then tap Settings.
  2. Scroll down the screen and then tap Privacy > Factory data reset.
  3. On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
  1. With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button..
  3. Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.
  4. Press VOLUME UP to start the factory reset.
Cell Phones Logo
How to unlock screen, when code number is lost?
Reset LG G2x P999 to Restore Factory Default Settings
How to hard reset (factory reset) the LG G2x P999?
There are two different ways you can reset your LG G2x P999 to its factory default settings, via settings menu and using phone buttons. WARNING!!! If a factory reset (hard reset) is performed, all installed application and user data such as messages, phone contacts, image, video and audio files will be erased. Please remember to back up any important data before performing a factory reset.
Reset LG G2x P999 using Settings Menu
  1. From the Home screen, press the Menu Key .
  2. Touch Settings > Privacy > Factory data reset.
  3. Read the warning and touch Reset phone.
  4. Touch Erase everything.
Reset LG G2x P999 using Phone Buttons
  1. Turn the power off.
  2. Press and hold the following keys at the same time for 15 seconds: Home Key+ Power Key + Down Volume Key.
  3. When the LG logo is displayed, release the keys. The phone will turn on and
    perform a factory reset immediately.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card.
Mar 26, 2015 | LG G2x / Optimus 2X 4G Android T-Mobi8GB...
Can you please reset my phone for me i cant get in my phone i cant get the voice off of my phone i cant use my phone im on my husband phone my phone number is 901)848-7623 i have a htc phone. Please help me thank you sherry faircloth
Feb 06, 2015 | HTC Cell Phones
hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
how to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
Performing a factory reset using phone buttons:
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
208 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
