Tip & How-To about Computers & Internet
How to format a computer with windows xp.
  1. The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
Computers & Internet Logo
how would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
How to reformat a pc?
Please go through the below instructions, I have sent you the instructions for how to reformat a PC /laptop and I hope this will help you in understanding as well as learning.
If you have windows XP, 95, 98, or ME:-
How to Format a Computer with Windows XP:-
  1. The first step in learning how to format a computer with Windows XP or 2000 is to insert Windows CD and restart your computer.
I have no clue which windows are you using ,i have sent you one post for Windows XP and will also sent you the post for Windows 95,98 or ME.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 20, 2009 | Computers & Internet
step 1-insert ur windows xp os cd
step-2restart ur compuiter
step-3 while windows is rebooting after restaret just keep jabbing F8
step-4 select the hard drive of ur cd drive
step-4 installation [process will start and u can continue on you own if not mail me
snakeatstar_1990@hotmail.com
Oct 04, 2008 | Microsoft Windows XP Professional
how i can format my Mirra Personal M-120?
1. Make sure the CDROM is set as the first boot device in BIOS.
2. Insert the Windows XP/2000 cd in the CDROM
3. Restart the server
4. When 'Press any key to boot to cd' message is displayed, press any key
5. Follow the steps to reinstall the operating system, one of your options will be to format (I would recommend NTFS)
Hope that helps!
Les
Oct 18, 2007 | Mirra Personal M-120 (m020120) Server
156 people viewed this tip
David Payne
David Payne
