Tip & How-To about Cell Phones
Load applications onto your blackberry.
To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an application called blackberry desktop Manager (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.Accessing the Blackberry Application LoaderAfter BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:1. On your PC, select Start --> Programs --> BlackBerry --> Desktop Manager.BlackBerry Desktop Manager opens.2. Connect your BlackBerry to your PC via your USB cable.Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.3. Enter your password.This completes your BlackBerry-to-PC connection.4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.Using the Blackberry Application Loader
To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:1. Launch Application Loader from BlackBerry Desktop Manager.
The Application Loader Wizard welcome screen appears.2. Click the Next button.3. Enter your password, and then click Next.If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.4. Click the Add button.An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.5. Locate the ALX file and then click Open.You return to the Handheld Application Selection.6. Click Next.Doing so brings up the confirmation screen, listing the application to be installed.7. Click Finish.The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry
Cell Phones Logo
i have blackberry 8110 showing jum error 547
Hi, you need the desktop manager, and you need to download the current software version for that device, its going to wipe everything out on the device, but you will get the device to work. after you download the the software, you need to run it on your PC, and then use the APP loader on the desktop manager to install it to the device.
Step #1 Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Step#2 Make sure that you have installed updated device software installed in your PC.
Step#3 Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps: Connect the BlackBerry device to the computer running BlackBerry Desktop Manager. Open BlackBerry Desktop Manager. Double-click Backup and Restore. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases. Choose a location to save the backup file, then click Save.
Step#4 To perform a clean install of the BlackBerry Device Software, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click the Application Loader icon. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Click the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then click the check box beside Erase all currently installed applications. Click Next. Click the check box next to Do not automatically backup the application data during the loading process. Clear the box next to Backup and restore applications installed wirelessly. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Feb 23, 2011 | RIM Blackberry 8310 8320 8330 Curve 8100...
my blackberry is just sayingblockerase6 Reset
The Block Erase 6 Reset error may result from corrupt data on your BlackBerry device.
To resolve this problem, you need to complete the steps:
Reload the BlackBerry Device Software by following these steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Connect the BlackBerry device to the computer.
  3. Open BlackBerry Desktop Manager.
  4. Complete one of the following:
    1. If the Application Updates Available window appears, click Update Now. The Application Loader wizard appears.
    2. If the Application Updates Available window does not appear, double-click Application Loader. The Application Loader wizard appears.
  5. Click Next.
  6. If prompted, enter your BlackBerry device password and click Next.
    When the Application Loader wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation.
  7. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  8. Click Next.
  9. If the On the Device Backup screen appears, choose whether or not to automatically back up the BlackBerry device.
  10. Click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Inspite of this if you find the same error, you need to follow the steps:
  1. Remove the battery from the BlackBerry device.
  2. If a media card is inserted in the BlackBerry device, remove it.
  3. Connect the BlackBerry device to your computer using the USB cable.
  4. Open BlackBerry Desktop Manager and click Option > Connection Settings.
  5. In the Connection Settings window, click Detect. Make sure the BlackBerry device is detected.
  6. Close the Connection Settings window.
  7. In BlackBerry Desktop Manager, double-click Application Loader.
  8. In the Application Loader wizard, click Next to start the loading process. The Device Application Selection screen appears displaying the applications available to load onto your BlackBerry device.
  9. Select the check boxes next to the applications you want to load. Check boxes that are already selected represent applications that already exist on the BlackBerry device. If you clear those check boxes, the applications will be removed from the BlackBerry device.
  10. Click Next. The Completing the Application Loader Wizard appears listing the applications to be installed and removed from the BlackBerry device.
  11. Click Advanced.
  12. Select the Erase all application data check box, and then click Next.
  13. Select the check box beside Do not automatically backup the application data during the loading process. This check box is selected because the data on the BlackBerry device may be corrupt.
  14. Reinsert the battery into the BlackBerry device.
  15. On the Application Loader wizard, click Next to proceed with the loading process.
  16. When the process is complete, the Application Loader wizard will display the following message: The loading operation was successful.
  17. Reinsert the media card if one was removed earlier.
  18. Close the Application Loader wizard.
Nov 16, 2009 | RIM BlackBerry 7290
what i need to do when black berry has error jum 102
You need to run application loader...
This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted.
The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone.
To reload the BlackBerry Device Software you need the complete the following steps:
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Oct 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
battery not holding charge
Hi
Please Reload the BlackBerry Device Software using Application Loader.
Following are the steps.
Note:The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding
BlackBerry Device Software using BlackBerry Desktop Manager version 4.5 to 5.0, perform the following step
  2. Click Help
  6. Connect the BlackBerry smartphone to the computer and open the BlackBerry Desktop Manager.
  7. Double-click Application
  8. Click Start under Update Software to start the installation process.
  9. Type your BlackBerry smartphone password, if prompted, and click OK.
  10. Select Options under Device Software Options.
  11. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  12. Click OK > Next > Finish.
  13. When the process has completed, the message The loading operation was successful will appear. Click Close to return to the BlackBerry Desktop Manager.
  14. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  15. Click Finish.
  16. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Please Rate and feel free to contact me
Sep 22, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackbeery 7290 every time I turn the radio on it reboots why?
Cause Summary of Causes
  1. The wireless transceiver software was not loaded onto the BlackBerry device correctly.
  2. There is a wireless transceiver hardware failure.
Cause 1
Resolution
Re-install the BlackBerry Device Software using BlackBerry Application Loader.
  1. Connect the BlackBerry device to your computer.
  2. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next.
  3. If prompted, enter your BlackBerry device password and clickNext.
  4. The Application Loader Wizard examines your BlackBerry device’s current configuration. When it is finished, the Application Selection window appears.
  5. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears.
  6. Do not click Finish. Click Advanced to begin loading the applications.
  7. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext.
  8. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete.
  9. Click Finish to begin the BlackBerry Application Loader process.
  10. Click Close when the loading operation is complete.
Cause 2
Resolution
Contact your service provider for more information.
Mar 02, 2009 | RIM BlackBerry 7290
166 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
