Tip & How-To about Health & Beauty
Skin tip -Treating Large Pores
Treating Large Pores.If you have large pores that resemble little holes on your skin, the following steps may be helpful. Stop using commercial products on your skin. Instead, use homemade skin cleansers. Splash warm water onto your face and pour half a handful of stone-ground cornmeal into your wet palm. Massage the moistened meal into your entire face area, adding water as needed. Another homemade cleanser can be made by adding a few drops of lemon or lime juice or apple cider vinegar to milk (use powdered skin milk if your skin is oily).
Soak yarrow (check health food stores or botanical supply stores for this herb) in water overnight, and apply this astringent several times a day - less frequently if your skin is dry.
Avoid all creams. Use an unsaturated vegetable oil if you need to (e.g. vitamin E oil).
Health & Beauty Logo
My facial skin looks old, wrinkled and my pores are huge 7 weeks after co2 laser treament....Help!
do not go back to the treating person until you see a skin specialist
that way you will know what went wrong and will know it the treating person really can help fix the problem
Mar 18, 2017 | Health & Beauty
Do I need to use an eye cream? Can my facial moisturizer work under and around my eyes just as well?
All Hormeta moisturizers can be used around the eyes. However, the skin around the eye area is a lot different than the rest of the face. There are no oil glands there, so skin tends to get dry and wrinkled. Also, the skin of the eye area is much thinner and can't absorb heavier products. A separate eye cream should be used to solve specific problems around the eye such as fine lines and dark circles.
Nov 23, 2010 | Health & Beauty
How can I make the pores on my face look smaller or even gone? My pores are really big and I find it difficult to get the look I desire.
Most enlarged pores on the face are the result of hereditary factors more than anything else. You really cannot make the pores disappear. You will have to create the illusion of a poreless complexion. Apply foundation, concealer, powder and blush in a downward motion, otherwise you'll accentuate pores by pushing color up and into them. For a temporary fix, especially for a special event, I recommend using Colosé Serum Vital Lifting. It tightens and tones the surface layer, refreshs, moisturizes and firms your skin. With the first application the skin becomes even, smooth and has a radiant appearance. The tightness last approximately 4 to 6 hours and definitely makes your pores seem much smaller or even gone. Apply before makeup and let completely dry.
What is the best treatmentfor oily skin?
The treatment for oily skin requires a cleansing routine morning and night. The routine begins with a cleanser formulated to lift the excess oil out of your pores. Colosé Skincare makes a lotion called Lotion Nettoyage that contains coconut oil, which deeply cleans pores and helps heal blackheads and pimples. You leave this on for five minutes then rinse it off and follow with a toner. I would also suggest either the Green Clay Mask of Colosé or the Herbal Treatment Mask two times a week to get a totally clear and smooth complexion.
1,402 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
