Tip & How-To about Health & Beauty
Perfume and Weather
Be aware of the weather. On hot summer days, scents tend to last longer whereas cold weather has the exact opposite effect. So, vary the amount of perfume you wear with each season.
Health & Beauty Logo
what are the tyre pressure of a ford focus 1.6 automatic 2014
Coming from someone who has worked for Chevy,Ford,and Chrysler dealerships we had to gauge the tires by what the sticker said on the door jam at the driver side..I disagree with it...It is always best to gauge tires with the outside temp because cold weather and hot weather make a huge difference...NASCAR racing can drop a tire pressure on one tire and raise it on another for better traction on the constant left hand turns...Just a 1/2 of a pound can make a huge difference..Tires tend to swell in hot weather and on long trips..another reason it normally says to gauge a tire while it is cold which means been sitting still overnight..It doesn't mean cold weather...However tires won't swell in cold weather...I like running 40 psi in tires if it says 32 or 35....this will give you a good flat even tire wear...I have always added 5 pound to whatever it told me to gauge it at...If a tire wears out on both edges it indicates low air ..,also tire alignment can wear one side of the tire....If it wears in the center it means too much air...It is hard to keep them perfect because of rotations..,weather ,and certain terrain but it can be done by checking them every month....Some tires have different pressures written on them that is different than the door sticker...To answer your question ...Add 5 pounds to the door sticker...,your tires will last longer..They won't last as long with door sticker pressures which will give dealers more tire business...Another thing dealers do is put nitrous in tires instead of air which is supposed to keep air from swelling and changing in the summer and winter...This is good..It isn't Nitro that explodes.....Always tell them to gauge them with your choice of tire pressure....
Feb 22, 2015 | Ford Cars & Trucks
How many hours of light do reptiles need throughout the day?
The amount of light a reptile requires varies between the winter and summer seasons. During the winter, reptiles need approximately 10 hours of light and 14 hours of darkness; whereas during the summer months the amounts flip.
Sep 04, 2012 | Aqueon Reptile
What type of fragrance lasts the longest when sprayed? For example: toilette, parfum, body spray (like at Bath& Body Works)... etc. Also, any advice on how to keep the fragrance from "fading" so that the scent lasts the whole day?
The concentrate always last longer....oil-based fragrances are also long lasting..this is evident with "attar", which is arabic perfume oil....very snice smelling...although tooo much of it can get to your head....about the scent lasting the whole day...i believe its not possible...although some fragrances last longer on some skin types...your best bet is to keep trying the ones you like and see which lasts longer....or you can re-sprray during the day....lighter scents for the day time and sweet scents for the night time....
Nov 23, 2010 | Health & Beauty
OIl change
For Texas I would have used the recommended 10w-40 or the hot weather 20w-50. 10w-30 sounds like cold climate or new car oil. I hope you used the Amsoil motorcycle oil with the JASO MA rating. In hot weather you might find the 10w-30 oil will tend to burn off the walls of the cylinders( some day you will check your oil and find out you are a quart low.). Without the correct rating on the oil you will also increase clutch and gear wear. Do Not use any oil that says energy conserving on the label.
May 05, 2010 | 1997 Honda F6 C Valkyrie
662 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
