Tip & How-To about Apple iPhone Smartphone
How to jailbreak using sn0wbreeze (snowbreeze) on all iDevices
This will guide you on updating, hactivating, jailbreaking and keeping your baseband ready for unlock by using sn0wbreeze 2.1
This jailbreak is great for iPhone users who's been waiting to update to iOS 4.1 but wants to keep their unlock to keep the phone functionality.
Because this jailbreak process involves updating your iDevice's iOS version, I recommend saving your iDevice's SHSH blobs NOW! CLICK HERE to learn how.
iDevices that are not listed above are not compatible with new iOS updates (from iOS 4.0 to the latest 4.1). DO NOT USE this jailbreak if you don't see your iDevice above!
Sn0wbreeze is currently for Windows only. Possibility of having a Mac version is uncertain.
These are the files that you need:
  1. sn0wbreeze 2.1
  2. Official 4.1 IPSW for your iDevice (select/click on your iDevice to download IPSW). If an Ad appears, just click SKIP THIS AD on the top left corner to continue on downloading:
The above list also represents all supported iDevices by sn0wbreeze.
Procedure:
  1. Run sn0wbreeze, click OK, click Close Credits and click Next
  2. Click Browse and locate the official 4.1 IPSW for your iDevice
  3. Select your IPSW and click Open
  4. sn0wbreeze identifies your iDevice base from the iPSW you selected. Once it's done, click Next
  5. Select Expert Mode then click Next
  6. Select General then click Next
  7. Choose your preferences then click Next Basically, the 3 options on the left are for iPhone 3G and iPod touch 2G users only because these features are already available (as a default) on newer iDevices such as the iPhone 4. Activating is for iPhone users only. Lastly, SSH is something that let's you access the files and folders on your iDevice. You don't wanna mess with this if it's new to you.
  8. Click Next again
  9. Click Build IPSW then click Next
  10. Wait until sn0wbreeze finishes creating your custome IPSW. Click OK once it says Done You will find the new custom IPSW saved on your Desktop. The filename should contain the word "sn0wbreeze_" on it so there's no chance that you get it confused with the official IPSW from Apple. Watch this video...
  11. Plug in/connect your iDevice to your PC (computer)
  12. Turn your iDevice OFF and prepare to put it to DFU mode You can also opt to close sn0wbreeze and use iReb instead. Download iReb HERE.
  13. Click on Start.
  14. Press and hold POWER and HOME buttons for 10 seconds
  15. Release POWER but keep holding the HOME button for another 30 seconds
  16. Release HOME button once sn0wbreeze says Running iReb...
  17. After that it will tell you: Your device is now in a PWNED DFU state. Just click OK
  18. Then iTunes will detect your device in recovery mode. Click OK again
  19. On your computer's keyboard, press and hold SHIFT before you click on Restore (on iTunes)
  20. Locate the custom IPSW you created using sn0wbreeze
  21. Select the correct IPSW and click Open
  22. Click Restore and that's the final step. All you need to do now is wait. After the restore is done, iTunes will ask you to set up your iDevice. In case you come across any kind of error, use iReb to put your iDevice on a PWNED DFU state. Download it HERE.
Once that is complete, you will find Cydia on the 2nd page of your iDevice's homescreen.
And for iPhone users, next thing to do is to UNLOCK.
Credits:
iH8sn0w
kidantvideos
Apple iPhone Smartphone Logo
iphone 3g stuck sn0wbreeze logo
Try t o see if you are using the latest snowbreeze version which is compatible with iphone 3G.I will recommend you ti use WhitedOOr firmware for iphone 3G,as it is much faster to use.
Mar 16, 2013 | Apple iPhone 3G
How to unlock iPhone using PwnageTool or redsn0w + ultrasn0w combination
Hi i write hear because i have a big problems! I used this guide an everything was perfect until i decided to restore my iphone 3g with itunes. i had 1015 error so i tried to instal redsn0w again but alvays when i finsh the instalation proces i get screet to conect my iphone to itunes and the same thing again and again. How should i restore my iphone, is there any way to do that ?? please i just bought my phone one weak ago!
Nov 29, 2010 | Apple iPhone Smartphone
iphone went back to factory mode
You only need to connect it to a computer to activate it. But it you don't have a legit sim, there's no way for you to do that. Your only option is to Hactivate it by jailbreaking.
Jailbreaking will depend on what iOS version is currently installed on your iPhone. To check, READ THIS TIP.
To proceed with jailbreaking, choose from the tips below: For more tips and tricks for the iPhone, CLICK HERE.
Apr 30, 2011 | Apple iPhone 3G
I want Skype on my iphone 3G. please direct me to a link or suggest which version will work? Thank you.
All Skype versions work perfectly for the iPhone 3G, unless you did some buggy jailbreak. Go to the App Store app on your iPhone and download Skype from there.
If you're really having problem making it work, I would guess did a jailbreak using earlier revisions of redsn0w 0.9.7.. that's a little buggy release of redsn0w. To fix it, restore & re-do the jailbreak using a other tools such as sn0wbreeze.
CLICK HERE to download sn0wbreeze 2.2.1. For guide on how to use sn0wbreeze, READ THIS.
For more iPhone / iPad / iPod touch tips on jailbreaking and unlocking, CLICK HERE.
Apr 16, 2011 | Apple iPhone 3G
i have iphone 3gs , booltloader 06.04, baseband .05.14.02, OS 4.01... i accidentally upgrade its version to 4.1 after that i did downgarde to 4.01 using tinyumbrella n hactivate, jailbresk it using limeran1 but cant unlock d iphone to use in my carrier currrently nepal. how can i unlock the carrier lock to use iphone in any mobile network in Nepal.
You can certainly jailbreak, but you cannot unlock as of yet. It doesn;t matter if you downgrade the 4.1 firmware, that may help you jailbreak but it is the Modem Firmware or Baseband that matters. Your baseband upgrade camme with the 4.1 update. Since you are at 05.14.02, you cannot unlock as of now, period. You cannot downgrade the baseband on a 3GS, so jailbreak using Limera1n or Greenp0ison, but you need to wait for a new version of Ultrasn0w in order to unlock for anything other than AT&T.
Dont worry though, my sources tell me that the unlock is on it's way to be released.
Good luck, contact me anytime.
EJ Kudelka
Nov 23, 2010 | Cell Phones
2,772 people viewed this tip
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
