Tip & How-To about Acer Aspire One Netbook
Acer Aspire One Netbook Slow Wifi
Acer Aspire One Slow Wifi Using my Aspire One I noticed that, in spite of an optimum signal level, the surfing and page opening was slower than on my other computer. Looking through the web I found many other people were experiencing this problem so i have a suggestion for a solution that is working for me......
It seems like a problem with the power management on the wireless adapter.
To solve it go to the Start > Settings > Control Panel > System > Hardware > Device Manager. Then you have to expand the Network Adapters option and right click the wireless adapter "Atheros...Wireless Network Adapter"& select Properties then go to the Advanced tab. Now select the Power Save Modein in the left colum and set it on the right to Off Value, then press OK and close the device manager.
Acer Aspire One Netbook Logo
How do I adjust contrast?
There are Function Keys to do this.
from Troubleshooting section. Keyboard (if contrast and brightness function key)
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
and Page 10 of the manual
Display Keep your display clean. • Keep your head at a higher level than the top edge of the display so your • eyes point downward when looking at the middle of the display. Adjust the display brightness and/or contrast to a comfortable level for • enhanced text readability and graphics clarity. Eliminate glare and reflections by: • placing your display in such a way that the side faces the window or • any light source minimizing room light by using drapes, shades or blinds • using a task light • changing the display's viewing angle • using a glare-reduction filter • using a display visor, such as a piece of cardboard extended from the • display's top front edge Avoid adjusting your display to an awkward viewing angle. • Avoid looking at bright light sources, such as open windows, for extended • periods of time.
http://www.manualslib.com/manual/205261/Acer-Aspire-3680.html?page=10&term=contrast
Dec 27, 2015 | Acer Aspire 3680 Laptop
What causing that the Wi-Fi connecting at Windows8 faled every few minutes.???
Hi
The normal cause for WiFi failing regularly, dropping out, is due to distance from the WiFi signal source. This distance is not just feet and inches but also dependant upon the nature of objects between the signal source and the receiver. I recently found a case where the signal source had been put behind a large modern TV, and the WiFi signal in the next room was so slow and intermittent that the internet was unusable. Moving the router in front of the TV (in a position where it did not obstruct the picture!!!) cured the problem and they now have fast WiFi internet.
Oct 18, 2014 | Acer Computers & Internet
Aspire M3410
remove the bloatware from the computer, i.e. all the factory install junk you don't need. run a cache cleaner and a registry cleaner. you can find both tools in one program called ccleaner. you can download it from www.piriform.net
Feb 11, 2012 | Acer Computers & Internet
my new Acer Aspire one 722 wireless connection tested fine at the store. Web pages and file download is as expected for high speed network. When I brought it home to my high speed network, web pages and file download is painfully slow compares to my other laptops and desktop. Any ideal why and how to solve this?
could be just different wifi chipsets. these days also you may have 2.4/5ghz(802.11ac) what router do you have? most routers are now DUAL SIGNAL and have a 2nd wifi signal called GUEST generally this is for older slower WEP based security for old devices(which is what you have) as aspire one 722 is 802.11 b/g/N but not 5ghz and not ac. so its slow cos the router probably keeps negotiating for faster connection but your aspire cant do it and doesnt even know about it. Enable GUEST in your router and set it to N. How to Find the Best Wi Fi Channel for Your Router on Any Operating System https://www.forbes.com/sites/gordonkelly/2014/12/30/802-11ac-vs-802-11n-wifi-whats-the-difference/#6ec777d23957
Dec 20, 2017 | Acer Computers & Internet
my acer 3680 aspire is very slow on the internet
I am not sure what internet connection you are using but try disabling automatic updates in windows, this usually hogs the bandwidth. Also try using a different antivirus program (I use Avast Home Edition http://www.avast.com/eng/download-avast-home.html :: pretty good and fast, free antivirus system :: Make sure you remove any previous antivirus software first)
Alternatively you can update your software and drivers from here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Thanks
C
Mar 26, 2009 | Acer Aspire 3680 Laptop
3,594 people viewed this tip
Mohammed Ebrahim M
Mohammed Ebrahim M
