Tip & How-To about Health & Beauty
Makeup Brushes
Make up brushes are the key tools for flawless make up applications. While you choose your body lotion also check the quality of make up brushes and see the flamboyant glow on your skin. However, of the hundreds of make up brushes in the market how do you know which one is the best? Here are few guidelines on how to choose the right types of brush for an apt application.
Choosing make up brushes
Use natural bristles, which have soft touch and helps to apply powder blush, face powder, eyeshadow or lipsticks effectively. Use synthetic bristles for oil-based products like eyeshadow base, cream eyeshadows and concealers. Make sure that you choose dense brushes with silky texture and tapered round shape.
Make up brush maintenance
Wash them once a month with a gentle foaming cleanser, hair shampoo or just plain soap and water. Squeeze out excess water by laying them down flat between a soft folded towel and air-dry it. Wash lipstick brushes with gentle oil removing wash that you use for your skin. Avoid using the same make up brushes for light and dark shades. Throw away the worn out brushes lest it causes flaw in your make up. Replace them once in a year. Do not share the same make up brushes as it may lead to infection.
Health & Beauty Logo
Help to apply flawless eyeshadow
1. Start with the Perfect Eyeshadow Colors
Eyeshadow shades that match your eye color will enhance your eyes and make them appear bigger. Choose three shades of colors, but keep them light - darker colors can make your eyes actually appear smaller. If you are not sure what type of shades to choose, a consultation at a beauty salon may help you to find the most complimentary colors of eye makeup for your eyes.
2. Use the Right Types of Eyeshadow Brushes
It is best to buy three different types of brushes for your eye makeup applications. All brushes should have a flat half circle shape. The largest brush should have a soft tip, but the medium and smaller brushes need to have stiffer tips to help you control where the makeup is applied and how much of it is applied to the sensitive skin above your eyes.
3. Prime Before You Apply Eyeshadow
For a long lasting application of eyeshadow use a makeup primer made specifically for eye makeup applications. A primer is a silky smooth light liquid that will stop eye makeup from fading away by the end of the day. Even better, a primer will prevent the eye makeup from settling in the soft creases around your eyes.
4. Apply Eyeshadow Evenly
As you apply your eye makeup, take care to make sure that the application is even on each eye. Start by applying the lightest shade of makeup from the eyelash line to just under the brow with the largest and softest makeup brush. Next, use the medium sized brush to apply the medium shade to the eyelash line to the top of the eyelid. Lastly, use the smallest brush to apply a very subtle line of eye makeup just above the eyelashes.
5. Blend for a Flawless Finish
The last step is to use your large and soft eyeshadow brush, or a separate large and fluffy makeup brush, to gently blend the eyeshadow colors. Sweep the brush from the inside of the eye to the outside of the eye, and make sure you lightly brush the area from the lash line to the top of the brow. If you want to give your eyes a little pop, use the lightest shade of color and add just a tiny dab on the outside corner of each eye.
hope this help ;)
Oct 25, 2012 | Laura Mercier Health & Beauty
this lotion hide my spider veins and i would like to buy more - thank you
no its not apparently not...that product cant hide your spider vein the only treatment for that is vein stripping. go to dermatologist and ask for it thank you
Sep 07, 2011 | Avon Skin so Soft Renew & Refresh Age...
why is wella elan plus conditioning lotion not available.......what other products are available compatible to wella's quality & preformance
I have used Wella Elan extra hold setting lotion for many years. Now I can not find it any where. There is nothing else that I have tried that is close to being as good as Wella Elan EXCEPT Beautiful Body instant hair fortifier by Naturelle. I have been a cosmetologist for 34 years and I am so disappointed that it has been discontinued.
Beautiful Body instant hair fortifier by Naturelle can be purchased from Sally's Beauty Supply if you can not find it anywhere else. It cost around $7 or $8 for a 16 oz. bottle.
Jul 13, 2011 | Wella Elan Plus Conditioning Setting...
464 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
