Tip & How-To about Computers & Internet
How to Bypass Windows 7 Password´╝č
Question: How do I bypass a Windows 7 account password if the only account I can access is guest? Can I bypass Windows 7 password with the guest account? I forgot my Windows 7 administrator password, how can I regain access to my computer without the password? I have no Windows password reset disk.
Recently I met many similar questions. Are you troubled with the same problem, also forgot Windows 7 password? Well, before answering the question, you should understand what a guest account is?
What is a guest account in your Windows 7?
The guest account in your Windows 7 only allows people to use your computer without having access to your personal files. With the guest account, you can't install any software or hardware, change settings, or create a password. Because the guest account allows a user to log on to a network, browse the Internet, and shut down the computer, you should disable the guest account when it isn't being used.
Solution: After learning the definition of a guest account, you can understand it is not possible for you to bypass Windows 7 user password through the guest account. But you can bypass your Windows 7 password, with Windows Password Recovery Tool 3.0, a safe and efficient tool for you to bypass Windows 7 password. It allows you to bypass your lost Windows 7 password in less than 5 minutes.
What is Windows Password Recovery Tool 3.0?
Windows Password Recovery Tool 3.0 is professional Windows password reset software with 3 editions: Windows Password Recovery Tool 3.0 Standard, Windows Password Recovery Tool 3.0 Professional and Windows Password Recovery Tool 3.0 Enterprise.
It is designed to bypass Windows domain password, Windows administrator password and user password. With this Windows password recovery tool, you can instantly regain access to your locked computer by burning a bootable CD/DVD or USB flash drive on your own. No need to reinstall computer or pay to PC experts when you forgot administrator password or domain password on Windows 7/Vista/XP/NT and Windows Server 2008(R2)/2003(R2)/2000.
How to bypass Windows 7 password easily?
Step 1: Download and install Windows Password Recovery Tool 3.0 Professional.
Step 2: Burn bootable CD/DVD or USB flash drive.
Step 3: Set your locked computer to boot from CD ROM or USB.
Step 4: Choose the installation path of Windows, and enter the ID of the path.
Step 5: All Windows account user names will be displayed for you. Enter the ID of a specified User Name to remove its account password.
Step 6: Enter y to confirm and continue your operation.
Step 7: Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.
Step 8: Take the burned USB flash drive out of computer and press any key to restart your computer when you enter n to finish your operation.
The Windows 7 administrator password has been successfully reset and now you can access your computer without password. Please note this method to bypass Windows 7 password takes effect only when you log on computer after Windows 7 password reset.
Computers & Internet Logo
I have tried multiple ways of trying to bypass parental controls and windows 7 but nothing works
as you know on Guest account you can't do much of the stuff, so use the Administrator's account or create a new one for yourself.
Apr 03, 2013 | Microsoft Windows 7 Home Premium 64BIT...
How to bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password. First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on. Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection. To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again. Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do. Besides, you can also take use of Windows password reset CD to remove Windows XP password if you forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps. In fact, Windows Password Unlocker can be used to bypass windows 7 password, bypass windows vista password , bypass windows NT password and so on.
Mar 16, 2010 | Computers & Internet
365 people viewed this tip
David Payne
David Payne
