Tip & How-To about Harley Davidson Road Tech HA90 MP3 Player
Harley davidson 1550
My Harley Davidson has a 1550 big bore kit and now it popping and back firing when you try to feed gas to motor and sounds like a knock in the motor
Harley Davidson Road Tech HA90 MP3 Player Logo
MY 2001 ROADKING WITH CARB I INSTALLED 95 IN
Try and get the carbs balanced .You may have one in need of adjusting .
Mar 17, 2010 | 2001 Harley Davidson FLHR - FLHRCI Road...
1550 motor makes noises
most left hand noises invole the compensating sprocket/alternator area, and back along the primary chain to the clutch hub. bearing failure would be noticed at low rpm, so i doubt this problem has anything to do with your 1550 kit
Jun 14, 2009 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
1559 motor makes noises
CHECK everything in the primary, primary chain, adjuster & shoe, all bolts, clutch parts, and very important check alignment of primary chain. If motor was pulled from bike inquire as to if when motor put back if alignment tool was used. Good luck.
JP
645 people viewed this tip
Top Harley Davidson Audio Players & Recorders Experts
Jim Goldsmith
Jim Goldsmith
Stephen Burdy
Level 1 Expert
xxxxxx xxx
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
