Tip & How-To about Philips 60P8342 60" Rear Projection Television
Video Shrinking/Expanding Or No Audio/Video
If your Philips Magnavox Projection TV has the following symptoms....
Video screen shrinks and expands.
Or
No Video or Audio - But the power light comes on!
If you have either of the two problems listed above its likely that the opto isolator IC has failed.
You can get repair instructions and parts from the following site.
http:///www.magnavoxhelp.com
Philips 60P8342 60" Rear Projection Television Logo
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
how to adjust picture on projection TV
It should have in the menu ,under settings ,, convergenge,, it realines the colors,, ,,
Oct 03, 2008 | Philips 60P8341 60" Rear Projection...
magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
picture problem
philips part# 483520988561 actual part# HCNW136 opto coupler datasheet at datasheetcatalog.com can buy many places just enter it on google.
other fixes philips part# 483520987834 actual # MC34065p and philips# 483520987712 actual# SC78104 some change all 3 and never have a problem again.
Nov 22, 2007 | Philips Magnavox 9P6034C 60" Rear...
1,628 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
