Tip & How-To about Computers & Internet
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
Computers & Internet Logo
connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
connected Cisco - cannot get connection to my laptop - reads Limited Connectivity
"Limited connectivity" means you did not obtain an IP address from the network. Type "ipconfig" at the command prompt to check - if your address starts with 169, it is an invalid auto-assigned address. Normally you would get an address in the range 192.168.x.xxx if it is working. Did you get a wireless connection but just no IP address? In other words, does your computer indicate "connected to xxxxx" (your wireless network name)? Check the router using a wired connection to get to the admin pages. Look for SSID (name of network), security settings and DHCP settings. Your security should be set to WPA2 (and the pre-shared key should be entered in your computer's wireless settings) and DHCP should be turned on and should have a defined address pool. DHCP is what assigns IP addresses; you can define a range of IP addresses to give out (the pool). If none of this works, please post more detail such as your router model and exactly what messages your are seeing.
Feb 21, 2011 | Linksys Computers & Internet
Network status is "Limited connectivity
Sometime the wireless card does not connect to the wireless router properly and you will get this error message. To fix, right click on the wireless icon on the Task Bar and then click Repair and the wireless router will issue a new IP address to the wireless card in your computer/laptop.
Nov 20, 2010 | Computers & Internet
Linksys adapter won't properly connect
Usually the limited or no connectivity is displayed under the following circumstances:
  1. The router and wireless adapter are too far apart.
  2. The network key (ex. wep, wpa, etc) your inputting on the computer is incorrect.
  3. The computer is obtaining the wrong IP address.
Judging by the fact that you already have had a computer connecting to the wireless network , I would assume your problem is going to be related to number 3. To make sure, I would first make sure that the wireless router is giving off a higher signal strength then 1-2 bars in the wireless network box in XP.
To confirm that it is correctly receiving an IP address I would change the connection to DHCP, which means the router assigns an IP address to the computer automaticlly. Here aree the instructions to do so....
  • Double click on the icon for the wireless network on the bottom right corner
  • When the box opens , click "Properties"
  • On the next box , double click on the line that says "Internet Protocol (TCP/IP)"
  • Next click on the radio button that says "Obtain an IP address automaticlly (DHCP)"
  • Then click on the radio button that says "Obtain DNS server address automaticlly"
  • Now try connecting to the wireless network, that shoud fix you up.
Also if that does not work , you can try this YouTube video which is great refrence for fixing a connection. Best of luck!
Sep 28, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Asus 802.11 a/b/g wireless adapter problem
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
Mar 25, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
1,136 people viewed this tip
David Payne
David Payne
