Tip & How-To about Computers & Internet
Speed up your computer
1 : Remove Spyware and Viruses Ads by Google
'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return;} google_ad_channel = '2748203808+7733764704+1640266093+5860073694+9911500640+9665908481+3607312525+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans;google_ad_client = "pub-9543332082073187";google_ad_output = 'js';google_ad_type = 'text';google_feedback = 'on';google_ad_region = "test";google_ad_format = '250x250_as';//-->google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);Spyware and viruses are leading causes of computer slowdown because you may have several spyware cookies or trojans that are taking up your processor time for reading and storing and reporting your activity to several spy databases. Update and run your spyware and virus software every week. Malware Bytes is one such programe which can help remove Spywares. 2: Defragment Your Computer -
Click start, again, then click run.
Type, "dfrg.msc" in the text field.
Click Defrag to start it.
3: Perform a disk clean up.
Click start in the bottom left corner, then click run.
Type, "cleanmgr.exe" in the text field.
Press "okay". This can take a while if you have never done it before.
  • 4 Remove unwanted/unneeded software which may be the reason for slowdown.
    • Click start, then click control panel.
    • Click add/remove programs.
    • Highlight any old software you do not use and then click "remove".
    5 Make Windows Load Faster
    • Click Start, then Run.
    • Type in 'msconfig' and press enter.
    • Click on the BOOT.INI tab at the top.
    • Over to the right there will be a box labeled Timeout with 30 in it. Change the 30 to a 3.
    6: Speed Up Processing Time
    Turning off the fancy Windows XP graphics will noticeably increase the speed of your computer.
    Go to Start, (Settings), Control Panel, System. NOTE: You may need to 'Switch to Classic Mode' to see the System applet.
    Go to the Advanced tab. Click the Settings button under Performance. Select the 'Adjust for best performance' radio button, then Apply, and OK. The graphics aren't as flashy, but your computer will run a lot faster.
    7 Set Pagefile size
    • Go to Start, (Settings), Control Panel, System. (This is just like the step above this.)
    • Go to the Advanced tab. Click the Settings button under Performance.
    • Now switch to this Advanced tab, and click on 'Change' under Virtual Memory.
    • You will see the 'Initial Size (MB)' and the Maximum Size (MB)'.
    • Change 'Initial Size' to the same value as 'Maximum Size' then click set.
    • Startup Manager and
    • Registry Cleaner.
    • Also go to Start/Run type in %temp% and delete them all.
  • Posted by on
    Computers & Internet Logo
    my computer is slow, will not install programs properly what is the problem
    you might try doing a factory restore
    Instructions
      • 1 Restart your computer and press the "F8" key when the Toshiba logo appears during the restart.
      • 2 Choose the "Repair Your Computer" entry on the page that appears and press "Enter."
      • Sponsored Links
        dmjs.revenueTags.push('ca-ehow_300x250;cpu_computer_hardware,text,suggested8'); googleAds.addAdUnit({ priority : 3, adUnitId : 'GoogleAdsense300x250', enabled: false, google_ad_channel : 'cpu_computer_hardware,text,suggested8', google_ad_client : 'ca-ehow_300x250', google_max_num_ads : '1', google_ad_type: 'text', templates: { text : ' \ Sponsored Links
          \ {! for (var i = 0; i \ \ {!= ads[i].line1 !} \ \
          {!= ads[i].line2 !} {!= ads[i].line3 !}
          \ \ {!= ads[i].visible_url !} \ \ \ {! } !} \
        \ ', image: ' \ Sponsored Links \ \ {!= ads[0].image_url !}\ \ ', flash: '\ Sponsored Links \ \ \ \ ' }, google_image_size : '300x250' });
      • 3 Select a language under the "Select a keyboard layout" drop-down menu and click the "Next" button.
      • 4 Type your password into the window that opens. Your user name should already be selected. If it is not, click the drop-down menu next to "User name" and select your name.
      • 5 Click "Toshiba HDD Recovery" at the bottom of the next page that opens. Click "Next" when the next two "HDD Recovery" windows open.
      • 6 Click "Yes" in the window that asks you if you want to recover your machine. The factory restore process immediately begins.
      • 7 Click "Restart" when the "Restart" button appears on the screen. The computer will shut down and complete the restoration to factory settings when it restarts.
  • Apr 14, 2013 | Toshiba Satellite Computers & Internet
    how do I set up my own elite proxy server?
    Setup your own Proxy Server in 5 Minutes for Free var google_adnum = 0; function google_ad_request_done(google_ads) { var u = ''; var i; if (google_ads.length == 0) { return; } else { for (i = 0; i ' + google_ads[i].line1 + ' ' + google_ads[i].visible_url + '
    ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + ' '; if (i '; } u = 'Ads by Google ' + u + ''; } google_adnum = google_adnum + google_ads.length; document.write(u); return; } google_ad_client = 'pub-3152670624293746';google_ad_output = 'js';google_ad_type = 'text';google_feedback = 'on';google_language = 'en';google_encoding = 'utf8'; google_max_num_ads = '2'; google_ad_channel='9126605320'; google_skip = google_adnum; google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google Google Analytics www.google.com/analytics
    Understand how people find, explore & convert on your site - Now free. google_proxy.jpg
    A simple Google search and you'll find dozens of really good PHP scripts on the Internet to help you create proxy servers in minutes for free. The only limitation with PHP based proxies is that you require a web server to host the proxy scripts and second, you also need a domain name to act as an address for your proxy site.
    If you don't own a domain or server space, you can still create a personal proxy server for free and that too without requiring any technical knowledge.
    Create a Free Proxy Server with Google App Engine Here's one such proxy site that you can build for your friends in China or even for your personal use (say for accessing blocked sites from office). This is created using Google App Engine and, contrary to what you assume, the process is quite simple.
    Step 1: Go to appengine.google.com and sign-in using your Google Account.
    Step 2: Click the "Create an Application" button. Since this is your first time, Google will send a verification code via SMS to your mobile phone number. Type the code and you're all set to create apps with Google App Engine.
    Step 3: Choose a sub-domain* that will host your proxy server. Make sure the domain is available, agree to the Google Terms and click save. The sub-domain is also your App ID that will uniquely identify your proxy application.
    For this example, we'll use labnol-proxy-server as the App ID though you are free to choose any other unique name.
    Step 4: OK, now that we have reserved the ID, it's time to create and upload the proxy server application to Google App Engine. Go to python.org, download the 2.6.4 MSI Installer and install Python.
    1_create_app_engine_account_thumb.png 2_verify_mobile_thumb.png 3_authenticate_thumb.png 4_create_application_thumb.png
    install_python_thumb1.png install_app_engine_sdk_thumb1.png sdk_preferences_thumb.png
    Jan 22, 2011 | Computers & Internet
    why i diD n0T uSe thE fAcebook siTe????
    Do you have any ad-Blockers? what is your firewall? any popup blockers?
    you may need to allow the website through your firewall if its not windows firewall
    if you have windows Firewall then an ad blocker/popup blocker is blocking it, allow www.facebook.com through that or turn off your ad blocker/popup blocker
    Q: why would an ad blocker/popup blocker block Facebook?
    A: Facebook contains elements that are often identified as ads or popups, Most of the content are popups/ads, and as such since the entirety of Facebook runs off popups/ads, that is blocked as a result of being identified as unsafe, do not be surprised, some websites are blocked like this that are actually safe and are otherwise known as False Positives in terms of spyware, viruses, Potentially unsafe websites, etc
    Q: Is there a solution? A: Yes, uninstall your popup/ad blocker IF you havent bought actually bought it and download and install Peerblock: http://www.peerblock.com/
    for your reference i have mine set to block: Anti-p2p Spyware Advertising
    and if you use Google Chrome or something that uses Google Chrome Extensions, install this, it doesnt block Facebook, but blocks all ads and saves your download bandwidth, i cant recommend this extension highly enough :) : https://chrome.google.com/extensions/detail/gighmmpiobklfepjocnamgkkbiglidom?hl=en
    tell us how you go
    Apr 20, 2010 | Facebook Social Network
    164 people viewed this tip
    David Payne
    David Payne
