Tip & How-To about Computers & Internet
You Tube, I need to get the latest Adobe Flash Player!!!
Together we, yes you and I, are going to be able to watch You Tube videos again. I myself, am a found you tuber and can't go without my daily dose. Some-times a message will display on your screen saying that you are unable to view this video as you do not have the correct or latest version of Adobe flash player.
This problem can easily be solved by downloading the very latest version of Adobe Flash Player, don't worry I will show you how!
Firstly we are going to go to the page Adobe Flash Player Latest download.
Now select Different Operating System or Browser, shown below cricled in RED.
Now Select your Operating System in Step 1 and your browser that you use in Step 2. Shown below, circled in RED.
You may now choose whether you would like to install google toolbar, tick for yes and untick for no!
Now you are ready to click the download button!
On the next screen you may need to follow the three steps displayed on the screen.
Now click the Install button on the box that comes up.
Well this should get you You Tubing in no time, I do recommend turning off your PC/Laptop and then powering on again as this means the latest Adobe Flash Player will load and it also reduces the chances of unnessary complecations.
Vista uses may still find the above procedure to bring them to the same sticky result as before, no You Tube for them.
Vista users listen carefully, you need to do the following in addition to the above.
1.)Navigate to the control panel.
2.)Double click Internet Options.
3.)On the Advanced Tab click Restore Advanced Settings.
4.)On the Advanced Tab click Reset.
5.)Click Apply and Ok to save changes.
Now turn off your PC/Laptop and power on again.
All done, you should be well on your way, You Tube here we come!
All the best and happy You Tubing!
damnor01
Computers & Internet Logo
how to increase my internet speed
To increase your internet speed
>You can use latest version of Firefox,or Google chrome or Opera browser.These are good browsers.
>Reset your modem and router or unplug them and replug it or switch off the modem and switch on it again daily twice.
>Try to avoid many downloads simultaneously.
>While watching videos online like Metacafe or you tube you can wait until the video buffers and then watch it.Avoid downloading while watching videos.
>You internet security software it helps to protect the PC or laptop from internet threats .If these will affect your PC or Laptop ,the system speed will get reduce.So browsers get crashes again and again,you cannot browse fast.
>You can use necessary addons only in Firefox.
>Clear cookies and browsing history in browsers daily.
Follow these steps it will helps to increase your dial up or any internet connection speed.
But your internet plan also need to be good.If you are using very slow speed connection,you can contact your ISP and upgrade your plan.Even after followed these steps your internet speed slow means you can contact your ISP and inform the problem.They will fix this.To check internet uploading and downloading speed i would suggest the site Scanmyspeed.com here you can check speed in Mbps and MBps.
Aug 31, 2013 | Microsoft Computers & Internet
Eight year old TV with a lot of miles. TV will turn on but for only about five seconds, then it will shut itself off and won't allow me to turn it back on unless I unplug the power and wait a few minutes, as if it needed to reset or something.
Make a fist bang on the tv frame bazel,see if u get a picture flashes?Most of these tv problems for an old CRT-(tv tube) design,tv have cold solders joints alots.If used like years in years out tv in used daily.U have a soldering iron,a roll of solders,can u do basic soldering also? Yes.Take the tv aparts resolder the FBT-the flyback tranformer,that the big black block of plastic with a red wire with a cap hook to a CRT-(tv tube).Also resolders the video board,that the board connect to the CRT-(tv tube) those pins sockets keep the video board and the CRT-(tv tube) together.Tv should be working again,if get these two soldering places parts resolders,FBT-resolders for stable tv high voltage.Video board pins sockets resolders for better joints connections between the video board and the CRT-(tv tube) connections.
Feb 03, 2011 | Sharp 27F543 TV
The TV typically works fine, however lately without any prompting when turned on sound is there without the picture. Turning the set on/off repeatedly used to help and eventually the picture would appear. Now though you are at the mercy of the set. any thoughts?
Make a fist bang on the tv bazel frame.See if u get a picture or flashes of a picture?If Yes,ur tv have cold solders joints on the tv video board,that the video board connected to CRT- tv picture tube.U have a soldering iron and a roll of sloders,also can u do basic soldering?Yes resolder all the Video sockets pins Holes that connected the video board to the CRT tube together.Tv shoud have picture again.
Jan 06, 2011 | Panasonic CT-36D30 TV
my power switch slides back and forth very loosely and won't turn on can i fix this myself?
yes if you can solder. New switches are about £1. Make sure the new switch doesn't overhang the motherboard or you may break it again.
Check you tube for instruction videos
If you can't fix it youself then you may consider removing the back of the DS, removing the on button and putting it back together so you can operate the switch with a toothpick.
Feb 14, 2010 | Nintendo DS Lite Console
picture on 52 inchtv shows a dark picture
If you go in to the tv menu, you should find picture adjustments. You can adjust the contrast and brightness to fit her preference.
Please give good ratings, it is important to us..
Aug 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
1,073 people viewed this tip
David Payne
David Payne
