Tip & How-To about Apple iPod touch
How to get password from router to put in ipod.
You must be wired directly to the router for this to work.
Click start button then type cmd and click on found item.Type ipconfig and hit enter.Look for default gateway and gateway address that look something like 192.168.1.1
Open up your Internet Browser
Type in the Gateway address in the Address Line and click enter.This should take you to the Main Page of your router
From there you need to follow along and read every page carefully. All routers are not the same but you should find an area that says Wireless and then Security. If you used WEP encryption, for example, you will find that information there. This should cover you with most routers.
Apple iPod touch Logo
We are trying to connect an iPod Touch Gen 4 to Thomson TG782T but it keeps saying unable to connect. We are entering the Wireless Pin # on the bottom of the modem. Can you please help?
Dec 19, 2010 | Apple iPod touch
configure my linksys wrt120n with the cd but can't found the internet all wiring are okay
1.Powercycle your equipment (unplug) Modem and Router
2.To ensure it is setup correctly the Ethernet cable should be plugged into the Internet port of the router
3.Wait 15 seconds and plug equipment back in
4.Check Firewalls Win XP: Start/Control Panel/Firewall/Turn off not recommended and try the internet
5.XP: Go to Start/Run/Type ncpa.cpl this will bring you to Network Connections/Double Click on Connection ensure the it is assigned by DHCP and it has a valid ip address it should start with 192.168.
Vista/7 Go to Start/Search Bar/Type ncpa.cpl and hit enter, right click on connection and hit properties. Uncheck Internet Protocol Version 6 and Click on Internet Protocol Version 4 and hit Properties. Ensure that Obtain and ipaddress automatically is checked as well as Obtain a DNS service automatically and hit ok.
6.Restart computer and Try to get online
7.Go to command prompt Win XP:Start/Run/Type cmd and hit ok Vista/7 Start/All Programs/Accessories/Right click on Command Prompt and hit run as administrator.
8.Type ipconfig /release and hit enter
Then type ipconfig /renew
9. Minimize command prompt and try browser
10. If still unable to access the internet open command prompt again and type:
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns and restart computer
Oct 02, 2010 | Linksys WRT120N Router
can't connect to to http address
Try plugging your computer directly into the range extender first, with an ethernet cable. Then check your computer for an IP. To do this follow these steps:
XP: click start> then run> type "cmd" and hit enter.
type "ipconfig" and hit enter, it should show you a default gateway address, that is the number you should type in your browser (IE: internet explorer)
Vista: click start> then in the start search type "cmd" and hit enter.
Type "ipconfig" and hit enter, it should show you a default gateway address, that is the number you should type in your browser (IE: internet explorer)
Jul 12, 2009 | D-Link DI-704P Router
ip conflict
Click Start, Click Run, type in CMD and hit the enter key, type ipconfig /all after the > sign and then hit the enter key, this will give you the ip address of the computer, the subnet mask and the default gateway, the DHCP server and the DNS server. You can reset the computer's IP address by typing ipconfig /release in the CMD window then typing ipconfig /renew. BPCS
Dec 30, 2007 | Belkin (F5D6230-3) Wireless Router
719 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
