Tip & How-To about Car Audio & Video
How to Enter a Renault Radio Code
This tip deals with instructions on how to enter the security code in your Renault car radio and assumes that you already have the correct code for your radio. It also describes what to do if your radio will not accept a code after too many incorrect entries and appears to be locked.
If you happen need a code for your Renault Radio I can also recommend this site which is cheap, fast and accurate and will email or text the code directly to you.
1) You must have 0000 showing on the display before the radio will accept the code.
If CODE or ERROR is on the display you must leave the radio switched on with the key turned to the first point in the ignition that activates the radio until the display changes to 0000.
This can take over an hour depending on how many wrong code entries have been made. It is very important to leave the key in the ignition turned to the accessories on position and the power must not be interrupted or the wait period will be reset and start all over again.
2) When you get 0000 on the display, use the steering stalk and not the radio to enter the code. Turn the thumbwheel on the stalk until the number changes on the display. Accept each number by pressing the satellite button on the bottom of the stalk before moving on to the next one.
3) When all four numbers are entered on the display you must press and hold the button on bottom of the stalk until you hear a confirmation beep. This may take up to 10 seconds.
4) Enjoy your sounds!
Hope this tip helps. Please do leave a vote for it and thanks for using FixYa.
Car Audio & Video Logo
how do i enter the code on a cd player... scenic
For instructions on entering the code for Renault please see this link.
This assumes you already have the correct code. If you need the code itself please see this link.
Thanks for using FixYa.
Sep 08, 2011 | Car Audio & Video
how to enter code in a renault magane radio, after changing the fuse ,,the radio locked,a code was put in ,but i cannot enter it ... how do i do that
Welcome to FixYa.
Please see this FixYa Tip which gives correct instructions on how to enter a code in a Renault radio.
Many thanks.
Sep 05, 2011 | Car Audio & Video
i have a 1999 renault laguna and recently had a flat battery as a result the radio blocked i have the code but incorrectly entered it now the word code remains . i have read you have to leave on for a while but can i have the engine running so the battery doesnt run flat or is the radio blocked for good
I have written a FixYa Tip which explains this issue of having to wait to enter the code for Renault. Full instructions on how to deal with it can be viewed here.
Please do leave a vote for the solution. Thanks for using FixYa.
Jan 25, 2011 | Car Audio & Video
i need the radio code for philips renault megane 1.9dci Year 2001
Please view this FixYa Tip which outlines the correct and exact procedure to enter the radio code for Renault. There is also a recommendation for a cheap way to obtain the code you require and reactivate the radio.
Many thanks for using FixYa.
Nov 26, 2010 | 2000 Renault 181
my car radio security code will not unlock radio
Are you sure that you have
1...The correct code?
2...The correct Code Entry Instructions
If you require a code the radio will have to be removed from the car dashboard .
Then please POST A NEW QUESTION quoting  the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
If your radio is a RENAULT/PHILIPS then here are the correct Code Entry Instructions
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Sep 14, 2009 | Car Audio & Video
2,308 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
