Tip & How-To about Garden
Things to consider before trying to Start a Chainsaw, Gas powered blower, Weed eaters, Mowers.
When starting a Chainsaw, Gas Powered blower, Weed eater or Lawn Mower; here are a few things to keep in mind.
1. Does it have a priming bulb? If so pump it 3 or 4 times before trying to start.
2. Do you have the choke pulled out or pushed down?
3. Is the Chain brake engaged?
4. Is it turned on.
5. Do you have it flooded? If so let it set for a 5-10 minutes and try again.
6. Do you have gas in it? Most saws recommend a 50:1 ratio. That equals a 2.6 oz of mixing oil to 1US Gallon of mid grade gasoline.
7. On bigger saws there is a decompression button located on the top, make sure it is pushed in.
8. While the choke is pushed down/pulled out, crank the engine until it "hits". On some saws, after it hits the choke will automatically go back in, but for the ones that don't manually push it in or up, then crank it again. It should fire.
9. On Poulan brand saws the choke is a little bit tricky on getting pulled out. It actually pulls out and up. You should fell it catch. When pulling it out and you think you have it out correctly, let off pressure from pulling it and see if it retracts back into the housing. If so, you didn't have it set right.
10. On mowers, do you have the blades engaged before trying to start? Mowers with a PTO button the engages and disengages the blades, pull up on the knob to disengaged.
Finally, I know someone may look at this and be saying to their selves, "do you think I don't already know this?" Well, you would be surprised at how many items get taken to the repair shop and the mechanic find out it was one of the simple steps above as to what caused the item not to start. Most mechanics will charge an hours labor fee just for a one minute fix. The labor fee can range from $10-$40/hour depending on the small engine shop.
Garden Logo
Weed Eater Priming
Check out the tubing to the carb. If it is good then the top part of the carb with the check valves is defective. If so, you need a new carb since those suckers cannot be fixed.
Aug 21, 2016 | Craftsman Weed Wacker Lawn Edgers
HOW TO ADJUST DRIVE CHAIN ON WEED EATER ONE
There is a tension adjustment on the body.. flip your mower over and you can see it better.. do not over-tighten it though because it needs slack to let the 1-2-3 to change on the fly.
Aug 18, 2014 | Weed Eater WE-ONE 26-Inch 190cc Briggs &...
what kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume this is 4 oz oil per gallon?
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
will not stay running act like it runnig out gas? and in back the motor real wet too. it a 450cxl poulan
The wetness, does it smell like the gas mixture. If so, one of the gas lines most likely has a crack keeping the gas from flowing to the carb which makes it quit running. When you prime the blower, this is when it will run for only a few seconds? This is because the primer bulb is taking gas and shooting it straight to the carb.
May 03, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
956 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
