Tip & How-To about Computers & Internet
D3dx9_37 is missing?
This is due to the fact that your Direct X 9 version is either out of date or just plain missing.
The d3dx9_37.dll file is one of many similar files contained in the DirectX software collection. Because DirectX is used by most Windows based games and advanced graphics programs these errors usually show up when using these programs.
To fix this it is as simple of downloading the latest version of DX9.
Click here to go to FileHippo and get the June 2010 version. Click on the green arrow to the right to start the download.
I've had many people ask me "how is this possible when I've just installed Windows Vista or even Windows 7." The simple answer is that when you install Windows Vista for example it ONLY installes Direct X10 components and when you install Windows 7 it ONLY installs DirectX 10 or 11. Therefore you will need to seperately download and install DirectX 9 in order to play games in DirectX 9 solve this problem.
If installing the latest version of DirectX 9 doesn't solve the problem then do the following:
  • Explore the game CD you are trying to use and find the DirectX 9 version the game or program came with. Install this version.
  • Uninstall the game or software and then re-install it. One of the files associated with d3dx9_37 may have been overwritten or deleted by accident.
  • You could try extracting the d3dx9_37 from the DirectX 9 package and placing it where it needs to be.
  • Re-install or update your graphics card drivers.
Computers & Internet Logo
i get the d3dx9_28.dll was not found error
This is a missing or corrupt direct x 9 file redownload and reinstall the file here, http://www.dll-files.com/dllindex/dll-files.shtml?d3dx9_28
Mar 22, 2011 | Buka Entertainment Pacific Storm for...
I have a program I am starting that says I'm missing a d3dx9_30.dll missing on my computer. How can I fix this.
Maybe this will help;
http://www.dll-files.com/dllindex/dll-files.shtml?d3dx9_30
There is an error with directX
Feb 07, 2011 | ASUS Computers & Internet
how do i fix: "Failed to get address for D3DPERF
YOu need to update your DirectX. If still the problem exists then use a system utility software to repair your windows corrupt files, registry files and fix different operating system errors. I would recommend you to use system utility software RegInOut. Hope it works for you.
Jan 07, 2011 | Microsoft Windows XP Professional With...
i got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
May 12, 2010 | EA - Electronic Arts Command & Conquer 3:...
won't load program missing oleaut32.dll
You can download the dll file here:
www.dll-files.com/dllindex/dll-files.shtml?oleaut32
Mar 25, 2010 | Pinnacle Studio AV/DV version 8...
547 people viewed this tip
David Payne
David Payne
