Tip & How-To about Cell Phones
Rim Blackberry Separate SMS for Email
To do this
  1. Go to the main message inbox
  2. Go to inbox setting
  3. Under Other Message Types deselect SMS and MMS
  4. Save and you have now separated SMS from Emails
Cell Phones Logo
dnt knw the process to open a mms
Hi, the process of opening MMS is very easy if you have activated MMS feature on your Cellphone.
When your phone receives any MMS message a link will be in the Inbox of SMS or MMS you just need to open the message as you would open an SMS. That's it. The MMS will be opened on your cellphone which you can save on your Cellphone. Please contact the network carrier of your cellphone to download the settings for MMS and to activate MMS on your Cellphone.
May 02, 2011 | Cell Phones
My friend sent me mms on my N70 I tried to removed the message but I can't do it. Maybe you could help me erase the messages. Thanks
Hello - I use a Nokia 70 so hopefully I can help.
Scroll the centre button down to messages - press once to open. Move down one more setting to UNREAD messages and press again.
This will open ALL messages in you inbox - TXT/SMS + email + MMS.
Find your MMS by scrolling up/down then click the C (cancel) button bottom left on your phone. This should then ask - Do You Want to Erase this message - click YES.
The second option after you have found the MMS in the inbox is to open it, then press option which is the 'select' key on the left part of the screen. Press this once and you will have a menu of choices like -- move to / save picture / forward message to / save message on phone card // AND DELETE.
One of these should work if the phone is in good working order on all the other features. - Ray
Jan 15, 2011 | Nokia N70 Cellular Phone
unlocked european phone MMS
wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
-= MMS Web Session =-
Menu -> Web Access -> Web Sessions -> Menu -> New
Homepage: http://device.home
Service type 1: WAP
Gateway IP 1: 066.209.011.061
Port 1: 9201
Domain 1: (blank)
Service Type 2: WAP
Gateway Type 2: 000.000.000.000
Port 2: 0
Domain 2: (blank)
DNS 1: 000.000.000.000
DNS 2: 000.000.000.000
Timeout: 10 minutes
CSD No. 1: (blank)
User Name: (blank)
password 1: (blank)
Speed (Bps) 1: 9600
Line Type 1: ISDN
CSD No. 2: (blank)
User Name 2: (blank)
Password 2: (blank)
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: WAP@CINGULARGPRS.COM
Password: CINGULAR1
-= Message Setup =-
Main Menu -> messages -> Menu -> Message Setup
MMS Message Setup (This is very critical)
Inbox View: Sender
Srvce Center No: +13123149810
Auto Cleanup: 5 days
Email Gateway: 36245
SMS Alert: On
Use GPRS: Yes
-= MMS Message Setup =-
Main Menu -> Messages -> Menu -> Message Setup ->
MMS Message Setup -> Server Info -> Menu -> New ->
Service Name: CINGULAR MMS
Server Name: http://mmsc.cingular.com
Web Session Name: (Choose the Web Session you created for MMS)
set to default
Mar 10, 2008 | Motorola Mobility RAZR V3
RAZR V3XX - sends my texts as MMS, rather than SMS...
I had this same problem and called Motorola for support. The solution is to clear text/mms message inbox and outbox. The default setting on my phone was to never clear the inbox but I changed that to remove messages when they are 10 days old, I have not experienced the problem since.
Nov 07, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Saving Message
1st Open new sms click 'Inbox' select new folder create a name for your folder click save, click done then click Inbox select folder name you want the MMS to be saved to repeat for each one same for MMS & emails Once you have all your folder names you can click Inbox Msrk all choose one folder name and put all marked into same folder if you wish. They will go onto your phone memory by default. MMs & email you can choose whether phone or memory stick is your new folder location. Hope this helps One final comment when it says memory full it applies to your Inbox not genrally your phone.
Feb 10, 2007 | Sony Ericsson P900
158 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
