Tip & How-To about Gateway XHD3000 LCD TV
How to disassemble the Gateway XHD3000 30" LCD monitor
Basic disassembly information for the Gateway XHD3000 monitor
Provided by bammbammfran
Board repairs available
I recommend taking notes as you go or pictures and making which screws go to where since there are several different ones.
For further information contact
bammbamm@ptd.net
Gateway XHD3000 LCD TV Logo
XHD3000 seems to have bad inverter board. How do I get it repaired.
Sorry to say, but it is probably not the inverter.
Would need more info to try to see what it is.
I have fixed 80 of these in the last year and it is usually a controller board issue that causes almost all of the issues.
Apr 28, 2011 | Gateway XHD3000 LCD TV
Lost password for Gateway XHD3000
Please check with this following link. If this not helpful please contact technical support executive. http://support.gateway.com/s/Manuals/Monitors/8512788.pdf#page=1
Jan 03, 2010 | Gateway XHD3000 LCD TV
Gateway XHD3000 Monitor
I may be able to fix it for you
I believe the problem is in the same board that causing the strobing screen problem.
Cost is 150 to repair the problem board if it isfixable. No charge if not fixable.
You will have to pay round trip shipping for the monitor and power supply to Pennsylvania.
Ebays bammbammfran
Dec 29, 2009 | Gateway XHD3000 LCD TV
flickering blue sceen
If it's a Gateway XHD3000, I may be able to fix it for you
I believe the problem is in the same board that causing the full strobing screen problem.
Cost is 150 to repair the problem board if it is fixable. No charge if not fixable.
Ebays bammbammfran
Oct 04, 2009 | Gateway XHD3000 LCD TV
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
2,530 people viewed this tip
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
