Tip & How-To about Computers & Internet
Fix screen resolution (for not supported screen messages)
After failing to reset the screen resoultion in Safe Mode, try to get back into
Safe Mode and choose Use Last Known Good Configuration.
This should bring the monitor back to the last setting that worked properly.
Computers & Internet Logo
Your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders. Choose last known configuration to reverse to the most recent setting that worked. If a previous start-up attempt was interrupted due to a power failure or because the Power or Reset Button was pressed, or if you are not sure what caused the problem, choose Start Windows Normally. SAFE MODE SAFE MODE WITH NETWORKING SAFE MODE WITH COMMAND PROMPT LAST KNOWN GOOD CONFIGURATION (YOUR MOST RECENT SETTING THAT WORKED) START WINDOWS NORMALLY I CANT GET PASTED THIS SCREEN
Choose safe mode and see if you can get into it. If you can then go into system restore and choose the last date that you remember the computer working properly.
At this point the computer will restore the computer back to the earliest date that it was working properly.
Once you do this the computer will reboot and it should go back into windows normally and work just fine. If for some reason it doesn't then windows is corrupted and you'll need to wipe out the hard drive and restore the computer back to factory defaults.
Aug 21, 2009 | Sony VAIO PCV-V210P PC Desktop
WHAT TO DO IF MY SONY VAIO WON'T START?
Hi there.
Choose "LAST KNOWN GOOD CONFIGURATION" if it still won't boot up try "SAFE MODE" and perform a system restore and take the computer back a week or so.
Good luck and thanks for using FixYa!!
May 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
Jun 16, 2008 | HP Computers & Internet
Toshiba A100 Laptop Model PSAABU-215033
Have you tried to choose "Last Known Good Configuration Mode" If you haven't you may try to choose advanced boot menu by pressing the F8 key during the boot then choose "Last Know Good Configuration Mode" If issue persist please post for further assistance.
Good Luck
Feb 08, 2008 | Toshiba Satellite A100-S8111TD Notebook
132 people viewed this tip
David Payne
David Payne
