Tip & How-To about Computers & Internet
A list of compatible Graphics cards for an AGP8X Motherboard.
Due to text length contraits I've had to seperate AGP8X Graphics Cards from PCI Express Graphics Cards
Having trouble finding out exactly which Graphics card will work in your AGP8X motherboard? The following list displays all the compatible Graphics cards for an AGP8X motherboard in decending order (Top Graphics cards are faster than bottom ones in each catagory)
If your Motherboard supports AGP 8X then here is a list of compatible Nvidia cards.
GeForce 6 Series - (GeForce 6200, GeForce 6600GT, GeForce 6600 and GeForce 6600 LE)
GeForce FX Series - (GeForce FX 5950 Ultra, GeForce FX 5900 Ultra, GeForce FX 5900, GeForce FX 5900 XT, GeForce, GeForce FX 5700 Ultra, GeForce FX 5700, GeForce FX 5700LE, GeForce FX 5200 Ultra, GeForce FX 5200 and GeForce FX 5500)
GeForce 4 Series - (GeForce 4 Ti and GeForce 4 MX)GeForce 3 Series - (GeForce 3, GeForce 3 Ti 500 and GeForce 3 Ti 200)
GeForce 2 Series - (GeForce 2 Ultra, GeForce 2 Ti, GeForce 2 Pro, GeForce 2 GTS and GeForce 2 MX series)
GeForce 256 Series - (All)
If your Motherboard supports AGP 8X then here is a list of compatible ATI/AMD cards.
ATI Radeon X Series - (ATI Radeon X1050, ATI Radeon X1300, ATI Radeon X1550, ATI Radeon X1600 and ATI Radeon X1650)
ATI Radeon 9xxx Series - (ATI Radeon 9550)
For a list of compatible Nvidia PCI-Express cards for a PCI-Express Motherboard currently on the market click on the following link to take you to my other tips page. http://www.fixya.com/support/r6784358-list_compatible_nvidia_pci_express_16x
Computers & Internet Logo
ge force 9500gt, 512mb, ddr2 compatible with asus a7n8x deluxe
The ASUS A7N8X only supports AGP8X, the 9500GT is PCI Express. There is no way the 9500GT will work with this board.
Dec 12, 2011 | ASUS NVIDIA GeForce 9500GT, (512 MB) PCI...
hp pavilion slimline s5000 series whats the highest graphics card i can put in it
There are 14 different versions in the s5000 series of slimline desktop computers,
{From s5200z to the s5285t}
http://www8.hp.com/us/en/support-drivers.html
Some are Intel processor based, some are AMD processor based.
The Power Supply wattage differs also. Seems it goes from 220 Watts to 300 Watts.
All versions have a PCI-Express x16 expansion slot, though.
[ It is based on the PCI-Express 1.1 version technology
A graphics card based on the PCI-Express 2.0 technology will work.
Why?
Because PCI-Express 2.0 is backward compatible with PCI-Express 1.1
http://en.wikipedia.org/wiki/PCI-Express
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards. PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1. Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0."
Means;
1) Motherboards based on the PCI-Express 2.0 technology, are compatible with a PCI-Express graphics card that is based on the older PCI-Express 1.1 technology.
2) PCI-Express graphics cards are also generally compatible, if they operate at the smaller bandwidth of PCI-Express 1.1
Since the slower technology of PCI-Express 1.1 is what is available on your motherboard, a graphics card based on PCI-Express 2.0 will not operate at full capability.
{Graphics cards based on the new PCI-Express 2.1 technology will work also }
Will you notice?
No ]
What is the limit for a graphics card?
The sky.
Two problems though.
A) The Power Supply
B) The available room inside the computer case for a graphics card.
1) Power Supply:
According to HP Support, and looking at the specifications for the s5200z, and s5285t, the top of the line graphics card is an Nvidia GT220.
This is due to the low power consumption. (And probably reduced cost from Nvidia)
Based on price, and performance however, the GT220 is a less than choice.
Using a Zotac version as an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=348736&CatId=3669
Stream Processors = 48
You can have the fastest Core Clock, and Memory Clock, plus all kinds of graphics ram memory, but if you do not have enough Stream Processors, your graphics card will be less than adequate.
Consider Stream Processors as the 'Information Highway'. The path that graphics information takes from the Processor to the Graphics Card, and back.
If you do not have enough stream processors it's like a road being worked on.
Traffic is redirected into just one lane. Everything slows down.
There is a 'Bottleneck'.
Most decent graphics cards that are better than a GT220, require a Power Supply with 400 Watts, or greater.
The size and shape of the Power Supply's case, makes it hard to find a replacement that is greater than 300 Watts.
2) Available room for a graphics card (Height) inside the computer case:
With the Slimline case you have to purchase graphics cards that are Low-Profile.
{Low Height}
It isn't so much the length that you need to be concerned with, as it is the height of the graphics card.
The length of a graphics card goes from the back of the computer towards the front.
The height of a graphics card goes from side to side inside the computer case.
Average width inside a Slimline case seems to be around 4 inches.
You have to take into consideration; how far the motherboard is supported off of the support plate inside the computer case, and when inserted how high does the graphics card sit in the PCI-Express x16 expansion slot.
4 inches is Not enough room.
If it were I, I would remove all internal components, and install them in a cheap, decent, Mid-tower computer case. There is more room inside the case for a taller graphics card, and the case will use the common ATX style of Power Supply. A 600 Watt ATX power supply is pretty economical.
{There is also more room inside for air flow. Air is the cooling medium for a desktop computer. (Unless it's a high-end gamer computer. Dry Ice, Nitrogen, Refrigerant etc. have been used )
More air flow means cooler hardware components inside the computer.
Result? Longer life, more reliable }
Then I would use an ATI Radeon HD 5750 graphics card, (And a decent 600 Watt power supply)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=465512&CatId=3669
{A decent mid-tower computer case averages around $50 }
Regards,
joecoolvette
Sep 11, 2011 | HP Computers & Internet
dear sir, can i use geforce fx 5500 graphic card in mercury mainboard PI945GCM ?
Unfortunately the Geforce FX5500 is an AGP8X card and the mercury mainboard PI945GCM only supports PCI-Express 16X graphics cards.
You can find a list of all the available Nvidia graphics cards for your motherboard here: http://www.fixya.com/support/r6784358-list_compatible_nvidia_pci_express_16x
You can find a list of all the available AMD/ATI graphics cards for your motherboard here:
http://www.fixya.com/support/r6789140-list_compatible_pci_express_16x_graphics
Dec 19, 2010 | Computers & Internet
Graphics Cards
The Evga 7600GT is a AGP, you can't use this.
The ATI 2600 XT is only warranted for 1yr.
The EVGA 8600GT 256Mb is a Limited Lifetime. If only these three than the 8600GT Would be best.
Suggest you look here too.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10006326
Dec 25, 2007 | Computers & Internet
1,031 people viewed this tip
David Payne
David Payne
