Tip & How-To about Computers & Internet
How to disable hibernation in windows 7
Windows 7 doesn't make it easy to turn off hibernation. To solve this issue, Run REGEDIT, Navigate to
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power
and set HibernateEnabled to zero.
Computers & Internet Logo
MY WINDOW 7 IS NOT GENUINE
Go to run.type in regedit. go to hkey local machine.expand that. scroll down untill you find Windows NT expand that. click current version.expand that. go to winlogon.expand that. go to notify and delete that folder.say yes to the warning.go to computer click on your hard drive. search for wga tray. delete the wga tray.restart your computer for changes t take effect
Sep 09, 2012 | Microsoft Office Professional 2007 Full...
my sims3 game launcher says that my sims3 base game is incompatible with the sims3 expansion installed please update it via your game via game launcher. what can i do to resolve the problem?
Hi. I encountered the same problem when I install worlds adventures to my desktop. What solved my problem is to change the value of SKU file. To be able to change the value of that file follow these directions:
1. Go to RUN 2. Type in regedit 3. Open hkey local machine and then software 3. then sims and then sims 3 4. then you will find the SKU file try changing the value from 1 to 7 check if it should match your base game
Hope this helps your problem. Have a good day!
Jan 06, 2011 | Acclaim The Sims 3 World Adventures for...
I cannot uninstall easy share from my computer
Hi There,
In order to resolve this issue, we need a bit more information on whats the operation system that you are using.
Ok Lets assume that your OS is win xp for the moment.
Follow these instruction to uninstall the EASY SHARE from your computer :
*start-run-regedit-ok
*Click on HKEY LOCAL MACHINE -- SOFTWARE -- MICROSOFT -- WINDOWS -- CURRENT VERSION -- UNINSTALL ( you need to go to this location )
* there will be left pane and right pane.
* select one by one on the left pane under UNINSTALL and simultaneously check for the string called DISPLAY NAME on the right hand side.
* If you find the display name as or related to EASY SHARE, then simply delete the option on the left pane which enabled you to view the easy share on the right pane. ( remember that you need to delete it on the left pane under uninstall )
this will delete the EASY SHARE from for OS.
warning : Donot delete anything unwanted as this might corrupt your computer.
If you find this solution has fixed your issue then please vote for me.....
Enjoy and cheers !!!!
Oct 24, 2010 | Kodak Office Equipment & Supplies
Hi can't read any DVD or CD anymore I got Windows 7 HL DT ST DVD Ram GSA T50N Ata
First check in bios under boot device priority if cd dvd drive is listed or not, if not then reseat the dvd drive, if yes the follow the steps.
1. Uninstall the cd dvd drive from device manager and also ATA Channel0 and ATA Channel1 and restart the compter, and then check.
2. If the above step doesnt resolve your issue then
In the run box type regedit, go to HKEY LOCAL MACHINE - SYSTEM - Control Set001 - Control - Class - {4D36E965-E325-11CE-BFC1-08002BE10318} - On the right hand side check for upper or lower filters if you find one delete it.
Do the same with Control Set002 and Current Control set.
Restart the computer and you will see the issue is resolved for sure.
Apr 13, 2010 | Microsoft Windows? Vista Home Premium...
virus
Open Symantec.com and download Norton2007(Anti Virus) or u Can Try With E-Scan (Antivirus)
Gizmo1
Oct 18, 2007 | Microsoft Windows XP Professional for PC
560 people viewed this tip
David Payne
David Payne
