Tip & How-To about Heating & Cooling
Getting a solution to you're problem quickly.
Just a short tip for all of you good people out there, when you want a solution to your problem faster, please explain to us Tech's in as much detail as you can, by giving us the model, serial, and name of what ever it is you are having a problem with. For instance, you have a heater problem. Let me know if it is a wall heater, roof top or ground package unit, a split system. Tell me if it is a heat-pump, natural or propane gas fired unit, electric heat, or just a heat or cooling unit only. This will get us to jump on a solution much faster if we know this ahead of time. When we see a problem for example, my a/c or heater isn't working, we have to get more information from you to solve you're problem. So, if at all possible, try to give me as much information on what you have, and what it may or may not be doing. Being in the field of a/c & heating repair for many years, I have been able to solve a problem with in a few minutes by just hearing what the persons complaint may be.
Shastalaker7
Heating & Cooling Logo
CHECK POWERTRAIN warning light comes on dash,when running on LPG and happens randomly after after taking off? I turn engine off then start it again & warning is gone. Splutters heaps before stopping
the power train comprises the engine , transmission , drive shafts and differentials.
surging on lpg is an indication of the gas converter freezing up in the regulator and needs attention
for other details get a work shop manual for your vehicle as the areas are explained in detail with photos
Dec 12, 2015 | Cars & Trucks
We have Netflix and are on Series 3 of the good wife. Cannot get it anymore. It shows the picture, we select, and it doesn't start. We are old and would appreciate your help.
you may need better or faster internet,make sure the netflix stick is near your wireless,make sure that it didnt switch to someone elses wifi,or contact netflix,do i need to explain it again?see if the good wife opens on your computer
Jul 12, 2015 | Video Game Consoles & Games
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 13, 2011 | Maytag Ovens
maytag dryer neptune .8.8 code??????????
Open the control panel and you'll find a wiring diagram/tech sheet in there. It will have some troubleshooting tips, may explain the "8.8" in the display. If not, then the control board is probably fried. http://www.repairclinic.com/referral.asp?R=154&N=1164529 Good Luck, I hope this helped Please Rate me, Thanks
Dec 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
checking c3434
from its code no. in ZENITH tv  it seems to be located in power supply.(c3434)
please do not touch any thing if you are not  a tech person as you might be knowing that tv has very high voltage.
can you explain in details? so we can help you.
good luck.
Oct 09, 2007 | Zenith SY2788DT TV
178 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
