Tip & How-To about Cell Phones
Blackberry - Power Saving Tips
Charging
1. Charge Blackberry smartphone as much as possible
2. Use wall chargers as the preferred charging method
Media
1. Reduce volume
2. Use headphones
3. Load media using the Blackberry Desktop Manager
4. Turn off equalizer settings (media-options)
Browsing
1. Visit mobile sites where applicable
2. Turn Repeat Animations to a lower setting
3. Close browser when finished using
Screen/Keyboard
1. Reduce Backlight Timeout
2. Reduce Backlight Brightness
3. Holster smartphone (turns off LCD automatically)
4. Set Audible Roll to mute
5. Key Tone Off
6. Use a sleeve when storing the smartphone in a pocket
Network Connections
1. Turn off unused connections when not in use, such as GPS, Wi-Fi, Bluetooth
2. Use Auto On/Off
3. Use single mode only (2G only, 3G only)
Cell Phones Logo
my blackberry 8820 won't charge
What are you using to charge it -- the AC adapter (wall charger) or the car charger? Try using the other one and see if it will charge that way -- if it will, the problem is whichever adapter won't charge it. If neither will, then maybe you have a problem with the battery.
If you don't have a car charger, you can also try charging it from your computer by using a USB cable.
Aug 05, 2010 | RIM BlackBerry 8820 Smartphone
blackberry 9530 touch screen does not function
If the problem occurs while charging with the wall charger then try changing the wall charger.
Jun 08, 2010 | RIM BlackBerry Storm 9530 Smartphone
iPhone wont charge after plugging into the wall.
There are three solutions to your problem:
1) The battery needs to be replaced; or
2) The charger is defective (if you have a car charger you can use it to see if the phone will charge. If it will you'll need to replace the wall charger.) or
3) Your phone needs to be sent to a service facility for repair.
Feb 01, 2010 | Apple iPhone Smartphone
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
150 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
