Tip & How-To about Computers & Internet
Wireless Troubleshooting - What to Do For Limited Or No Connectivity on an XP Laptop.
Networking allows computers to interact, or share data, between themselves. Although they became easy to use over the years, issues such as "Limited or No connectivity" on Windows machines especially still occur. It prevents the computer, laptop, or any other device running Microsoft windows system from any network connection.
This would be very frustrating for a user who fails to solve the connectivity issue after several attempts. The "Limited or no connectivity" message tells the user that a problem has occur and needs troubleshooting. Below are some causes that may need looking at.
Physical causes and What to Do...
  • Network card could be faulty or malfunctioning, or the port on the card itself. Make sure lights show on the card and if they don't, replace with another one that works.
  • Check that your router or the server is turned on so that the laptop can acquire a valid IP address.
  • Double check to make sure the wireless card on the laptop is turned on. Do not assume it is on by default, do it yourself.
Logical or Software causes and solutions
  • Many of us are online buyers. Items sold on the internet, especially used items, are not in their default settings. Previous owners do not always reset them before sale, and this causes a lot of issues and unwanted beheaviours. Below are some of the common settings found on Routers:
    • ISP user name and password. If you want to connect to the internet check with your ISP to get your own User name and password, if not ignore this step.
    • Looking at the security options, make sure:
      • MAC address Filtering is not enable. If it is, remove all the MAC addresses on the MAC address table, and enter your Laptop's network card MAC address. With MAC Filtering On, do not forget to enter the MAC addresses of all you wireless devices on to its table.
      • Wireless key settings. Disable the wireless key settings and configure it to meet your requirements.
  • A Laptop to Laptop connection, please make sure the wireless settings on both laptops are the same.
  • Inconsistent wireless Keys. The key on the laptop has to match the one configured on the router.
  • Drivers out of date, update your wireless adapter drivers or your router firmware by checking the manufacturer web site.
  • Wireless not enable on the router. If wireless is not enable on the router, there is no Wi-Fi signal at all. some Router would have wireless turned off by default, and it is the administrator decision to use it or not.
  • DHCP Server misconfiguration. Make sure the DHCP (Dynamic Hosts Configuration) server is properly configured:
    • Enough IP address lease for your network devices
    • The server itself is not down
Some simple troubleshooting methods are:
  • Repair the connection. On Windows, click start - Control panel and then Network connections; chose the right connection icon, right then select repair. Windows will, temporarily, disable and re-enable your network adapter to attempt a connection.
  • Reset the IP stack. Click start then Run. At the command prompt type "command" or cmd for short, you are then presented with the command prompt window. Type "netsh int ip reset resetlog", and then restart your Laptop. This applies to desktop computers as well.
  • Reset the router to its factory default. Most routers we use at home are fitted with a reset button, by pressing and hold it for few seconds will bring the router to its factory default. This method solves a lot of the issues mentioned earlier, in one go.
Computers & Internet Logo
I having a problem with frequency. My phone and my neighbor phone seems to be on the same frequency. Is there any way to change this. When her phone rings our do also. We have called the cable n At&t, which came out n said it was the phones themselves. Please respond back as soon as possible. thank u for ur time
Telephone devices connected as alternative ansering allows for one person or the other to respond especially devices at the same residence. E. g. devices may share the same line like several telephones situated in the bed room interconnected to living room telephones allowing for the same person or owner to answer from any location of the structure. A situation that the telephone connection is thought to be malfunctioning requires consultation with the networking company. Usually, an experts technician would provide separate telephone lines to each devices least interfering with responses. alternatively, wireless telephone networking with modem installations provides residential, office locations networking where several devices share signals least interfering with neigbor response resources. Contact a network structure about wireless networking, broadband networking connectivity at residences, offices, schools or elsewhere.
Jul 20, 2011 | Lands Phones
There was a problem accessing your account. Please try again in a moment. Error #1
Yahoo messenger shares the internet connectivity to achieve telecommunication. Computers with stronger internetworking structures contribute towards attaining messenger experiences. First, the computer requires network cables that allow data sharing between several entities. Also, the computer requires enough memory capacity to sustain multimedia acquirable between messenger entities. Usually the computer requires sufficient spaces to attain the yahoo messenger as bundle of sot wares. Once the computer accommodate yahoo messenger, the internet connection capacity should allow files sharing beyond reading mail consisting of texts as the most minimal capacity to attain networking experiences. Second, yahoo messenger is capable of video conferencing requiring extensive capacity. First, wireless networks are available with broadband as capacity to accommodate huge media requiring sharing between devices. Cables media computers require high capacity wiring as a passage means to attaining media.
Mar 05, 2011 | Yahoo Mail
i cant find my archive to save but delete my message when i sign out
Feb 25, 2011 | Yahoo Messenger
The application failed to initialize properly (0x0150002). Click OK to terminate the application
Jan 28, 2011 | Yahoo Messenger
acer crystal eye webcam
GO INTO CONTROL PANAL AND LOOK AROUND, YOU MAY FIND WEB CAM DEVICE OR FOLDER THAT MAY ASSIST YOU IN THE AREA
*****************MOST IMPORTANT****************************************
CHECK YOU ANTIVIRUS AND FIREWALL AND WINDOWS FIREWALLS AND WINDOWS DEFENDER, AND INTERNET ANTIVIRUS PROGRAM MAY STOP YOU FROM USING THE WEBCAM AND ANY OTHER DEVICE LIKE THAT, ESPECIALY WHEN YOU ARE ONLINE AND YOU WANT TO SHARE FOOTAGE WITH EACH OTHER, YOUR FIREWALL OR WINDOWS
DEFENDER MAY NOT ALLOW THAT INTERACTION WITH YOUR FRIENDS.
*************************MOST iMPORTANT***********************************
SO CHECK THE NETWORKING AND SHARING FOLDER MAY ALSO NOT
ALLOW WEBCAM INTERACTION BECAUSE THE BOX IS NOT MARKED
OR PUBLIC NOT MARKED EITHER OR SHARING OF INFORMATION WITH
FRIENDS..
WEBCAM SETTINGS MAY BE IN WINDOWS MEDIA CENTER, WHERE
YOU DO RECORDINGS, MAKE MOVIES, EDIT PHOTOS
FEW OTHER PLACES TO LOOK AT
ROD
Jan 25, 2009 | Acer Aspire 4520-5582 Notebook
222 people viewed this tip
David Payne
David Payne
