Tip & How-To about Computers & Internet
How to replace the battery on the iPAQ 3800 and 3900 Series
Before starting the installation, please ... - Be careful when handling and Apple ibook g4 battery. - Care of common sense in handling the battery as to not bend (ie, bending), away from metal, away from extreme heat, etc. - Make sure all the data into iPaq have been saved.
- Care of common sense in handling the Battery as not to bend (ie, bending), away from metal, away from extreme heat, etc.
- Make sure that all data were saved in iPaq.
- Read all instructions before your first attempt to replace the Dell XPS M170 battery. This will help you visualize the process before it even began.
1. Turn the power off, and make sure the reset button on the bottom of the unit is turned off to ensure the power is completely off.
2. Take pen from iPaq before continuing.
3. Using a Torx T6, get the four screws out of each corner. Make sure you do not lose the screws. Split the back cover of the main body by using your fingernail or other device such as a flat Phillips screwdriver. Make sure you
Do not scratch the surface when using a screwdriver.
4. Once the back cover is separated from the main body, open the back cover from the top. Do not leave everything the way that HP Pavilion DV2000 battery is attached to the motherboard via a flexible connector PCB. Note: A hard reset slide the door lock button and stylus are not attached to the body, and therefore, they can be loose as the back cover is removed. They are easy to rear, but it is wise to take note of their location and position.
5. As you remove the back cover carefully, you will see a connector between Compaq NX7010 battery and the main board. Carefully remove the connector Battery. Please note that the Battery is glued to the back cover, and can be removed after
Unplug the connector on the main board.
6. Once you have the old Battery removed, align the new Sony vgp-bps9 battery so that the edge of the Battery which is closest to the connector goes to the bottom (for example, the side is recorded on top).
7. Press firmly on the connector Battery. Make sure all corners are firmly inserted.
8. From the bottom, reinsert the backcover. Do not force the lid when closed. This means that the Apple A1022 battery is not properly installed on the back cover. Just realign the stack so it is secure.
9. Insert four screws back and turn the key to reset and power button, in that order, to ensure that the device operates normally.
10. You must fully charge the Battery, And let it charge for more than 30-60 minutes after the full load indicator is lit. This ensures that the Dell latitude d620 battery is fully
Computers & Internet Logo
I would like to install a new optical drive in an iBook G4 1.42 GHz
Take the back cover off and unscrew the screws. Then make sure that you deal carefully with the ribbon cables.
Mar 20, 2013 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
I have an apple ibook G4. It won't charge and
hello Um i had the same problem as u. its ur dc board it connections are lose or just broken off inside the machine i had to replace the dc board on my ibook g4 2004Late it cost me about 25$ i recall there on ebay for that price when i got mine.
Dylan Macleod
Oct 20, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
when i turn my ibook g4 on, it asks me for a password. ive never installed one. is there a default password i can use?
for resetting the admin password w/out cd.
It's amazing the things you'll find with a search engine.
Mar 25, 2009 | Apple iBook G4 Mac Notebook
256 people viewed this tip
David Payne
David Payne
