Tip & How-To about Computers & Internet
How to give your iPod a longer battery life
Everyone wants to keep their iPod pumping some excellent songs, but eventually it will run out of power. There are some simple and effective tips you can use to increase the Apple macbook pro 15 inch battery life of your iPod by almost half.
- Backlight
Turn off the light back can save a massive amount of power. It is defaulted to ON, if every time you touch the scroll wheel, the light illuminates. Disable it to see a big difference in the lives of Dell inspiron 1545 battery!
- Volume
Yes, everyone loves his music is strong, but it is actually Dell Inspiron 2650 Battery down quickly. If you're on a long trip, keep the volume a little more than halfway there. This way you will be able to squeeze in that extra album or a favorite song.
- Full Load
Charging iPod completely before use with a iPod charger will make a big difference. Pumping as much power in the Dell Latitude D820 Battery as possible, it will hold more than electrical reactions take place inside. The longer you leave the charger plugged sector ipod better, even if the sign is fully charged up!
- Clicker
Even if the clicker uses a small amount of energy, it can add up to a lot over a long period of time. Turn it off and you will see that you have more power than before, and people sitting next to you will not be bored any more when changing tracks.
Computers & Internet Logo
my laptop not running by electricity but it running battery. I dont understand what's problem
nilpadda,
You probably have a broken power jack. If you are sure that it does not see AC do not use the unit. If you do you will eventually destroy the power section on the main board and face the expensive repair bill of replacing the board. If you take it to a reputable repair shop now and have the power port replaced you will save alot of money later. This is not something you can do yourself. Total cost to repair should not be more than $150 US.
Thanks for using FixYa and for the excellent rating. Great ratings keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | IBM ThinkPad T40 2373 Notebook
starts runs for a minute two the shuts down and blowes smoke
jerome kr406,
This is a classic problem with the reddy heaters. They have a filter which over time plugs up. This causes the air/fuel mixture ratio to change because the pump pressure is determined by the air bleed. As the filter plugs the air pressure drops and the fuel also drops meaning the burner is running lean. This eventually causes the unit to shut down and as you said smoke comes out. It is a fairly easy fix and I have a tip which will walk you through it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters . My tip will link you to the place to get the parts you need as well as how to perform the additional maintenance that these heaters require.
Thanks for using FixYa and for the excellent rating. Great ratings help to keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
80gb new ipod wont sync
Go to http://www.findleydesigns.com/. They have an excellent utility for under £15 for both Mac and Windows. It also means that you can add anyones iPod music to your iTunes library. VERY easy to use.
Nov 06, 2008 | Apple iPod MA446LL/A MP3 Player
ipod
flip the shuffle button thing on the bottom then flip it back then press the menu and middle buttons at the same time till theres an apple logo and connect it to ur computer ot restore it.
Jul 02, 2008 | Apple iPod nano
transfer problems
For everyone who has an iPod that has frozen, letting the battery run in an option, another way is to press the center button and the menu button at the same time. just for a couple seconds. keep the hold button off. this worked on mine
May 15, 2006 | Apple iPod mini M9160LL/A MP3 Player
167 people viewed this tip
David Payne
David Payne
