Tip & How-To about Microsoft Windows XP Professional SP3 Full Version OEM for PC
Windows Tips and Blogger Templates, CSS and Google Fonts
Need help and advice with Windows Operating Systems and Blogger then visit the Windows Tips Club and Blogspot with our RSS feed
http://www.windowstipsclub.com
http://windowstipsclub.blogspot.com
http://feeds.feedburner.com/WindowsTipsClubBlog
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
synchronization error
This happens because you have RSS Feeds, from Microsoft, and they are losing the connection, sometimes, this can be quite normal. If you do not want the to appear any more simply turn off your RSS feeds.
Apr 17, 2010 | Microsoft Windows XP Professional
How do you get rid of a microsoft feeds synchronization error
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the View menu, point to Explorer Bar, and then point to Feeds.
  3. In the navigation pane, right-click a feed, and then click Properties.
  4. In the Feed Properties dialog box, under Update schedule, click Settings.
  5. In the Feed and Web Slice Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed and Web Slice Settings dialog box.
  7. Click OK to close the Feed Properties dialog box.
Windows Internet Explorer 7
  5. In the Feed Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed Settings dialog box.
Dec 25, 2009 | Microsoft Windows XP Professional
microsoft window encountered feeds synchronisation problem
It is part of the Windows RSS platform that monitors the RSS feeds you've subscribed to. If you don't use it, you can block it, but would be best to also turn it off:
  1. In IE7 click the Tools button and select Internet Options from the pop-up menu.
  2. On the Content tab of the Internet Options dialog box, click the Settings button in the Feeds section of the dialog box.
  3. In the Feed Settings dialog box, uncheck the "Automatically check feeds for updates" check box.
Hopefully this will help. Thank you to Jerry on techguy.org for this answer!
Jul 06, 2009 | Microsoft Windows XP Professional
900 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
