Tip & How-To about Epson Stylus Photo 1280 InkJet Printer
Print Head Cleaning Cycle
Please confirm that the head cleanings were done using the most effective method listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s), your printer will require service.
Use the Printer Driver Utility to clean the print head. Alternatively, try this SSC Service Utility.
Also try changing the affected ink cartridge.
All else fails, your printer will require service.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Epson Stylus Photo 1280 InkJet Printer Logo
No instructions on how to adjust and clean printer. Getting poor qualaity lines.
  1. Select Hard Drive > Applications > Utilities. Open the Print Center. Proceed to Step 2.
  2. Highlight your printer in the list and then select the Utility icon at the top of the window or choose the Printer Utility in the Printers menu.
  3. Select Nozzle Check > Next.
  4. Examine the pattern that has printed. Each staggered horizontal line and straight vertical line should be complete and matching the pattern viewed on your screen labled Good.
  5. If all the lines do not meet then you must clean the printheads by clicking Clean. Click Finish if the nozzle check pattern has no gaps.
  6. After the printer has finished cleaning, click on Confirmation. Another nozzle check pattern will now be printed. If it is solid without any gaps, click on Finish. Otherwise, click Clean. Perform this step up to two more times, if necessary.
  7. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
  8. Once the cartridge(s) has been replaced, please follow steps one through six up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Feb 26, 2011 | Office Equipment & Supplies
epson rx 500 print problem
3. Click on START.
Jan 07, 2008 | Epson Stylus RX500 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
1) Make sure the printer is turned on but not printing.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
color of prints very faint
It is unfortunate that you are having this difficulty with your printer.
To help preserve the life of the ink cartridges we suggest that you turn the printer off when it is not in use.
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Nov 19, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
3,072 people viewed this tip
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
