Tip & How-To about Sony VAIO T140P/L (VGNT140P) PC Notebook
How to get a bluetooth headset to work
I bought this great little laptop in part because of the bluetooth support. I wanted to use a BT mouse first, but I also wanted to use a bluetooth headset for voip applications.
I was not happy when I found that the machine didn't do the 'headset profile' because it only had the standard XP bluetooth stack. I called Sony on this several times and was told that "you might be able to find a 3rd party bluetooth stack" but they could give no further information.
I had poked around the web and found a Widcomm stack. But I couldn't get it to recognize the BT radio in my machine. I gave up for a year or 2.
I got inspired recently to take another shot. I had a version of Widcomm 5 from one of the several BT dongle's I'd bought. I copied that onto my machine.
I had to figure out what hardware this machine used. Somehow I figured out (or guessed) that it was Alps hardware. So the Widcomm stack I have should work, since it was also for an Alps based dongle.
I tweaked the btwusb.inf file in the widcomm installation software. If you look at this file, you'll see a lot of entries that include something like this:
USB\VID_044e&PID_3001
I think that '3001' thing is a hardware identifier for another ALPS bluetooth radio.
I went into Device Manager and looked at the properties for my existing bluetooth radio. My hardware was
USB\VID_044e&PID_3007
So.. 3007 instead of 3001.
I went through the btwusb.inf file, and for any line which contained
I copied the "3001" lines (there were several) and changed it to 3007 . At this point, I was able to use device manager to change the driver to the Widcomm stack.
Next I ran the Setup program in the widcomm software.
It loaded up just fine and I can now use my headset.
Well, that only took 2 or 3 years to figure out..
Sony VAIO T140P/L (VGNT140P) PC Notebook Logo
My computer cannot seem to find my mouse. I am using a Lenovo thinkpad laptop and a lenovo thinkpad laser mouse but they can't seem to find one another!
Hi lucytru,
I see that your Laptop and BT mouse cannot detect each other or connect. I will be glad to give you info on how to make both devices detect each other on this query of yours, Follow steps below.
* On your screen lower right side you will see an Arrow pointing up click on it and it will show you all the applications running in the backround of windows look for the BT icon like the picture below.
* Right click on teh Bluetooth Icon then left click on open settings it will bring up the Bluetooth settigns page on the windows that will show look for the box on the top left where it says let this computer be detected by other devices will have a Box that you can put a check on for teh Bluetooth mouse to be detected by the Laptop.
* No need to resrt your computer it should work right away on this case.
I hope that this information will be able to help you about you concern, Have a nice day thanks.
Jan 26, 2011 | Lenovo ThinkPad Bluetooth Laser Mouse
Driver for Dell BT Travel Mouse
If it is a dell mouse, it should automatically work after a few things. Simply locate the button on your mouse to power it on, open your bluetooth settings on your computer and scan. It will then add the drivers as a HID (human interface device). If that fails go to dell.com, search for drivers & downloads under support and search for the drivers & documentation.
Mar 31, 2010 | Dell Studio 17 Laptop
Able to pair but not connect w/ BT trvl mouse/Dell 1525
did you shut down firewall and or allow it threw your firewall...Check this===.rick click computer, left click propertys.click device manager.look see if u see any yellow question marks there.if so needs updating..i would try a system restore back to before you did these updates which apparently have affected your mouse..if u did not create restore points then your pretty much gonna have to do a redo of OS. YOU HAVE GOTTEN BAD UPDATES THAT ARE AFFECTING YOUR PC..my advice to everyone is to always first thing make back up disk,make restore points at least twice a week.back up back up people this all saves so much trouble..
Oct 07, 2009 | Dell Inspiron 1525 Laptop
acer aspire 4730z bluetooth problem
Yes your Machine got WPAN: Bluetooth® 2.0+EDR (Enhanced Data Rate).
If its not working then you need the drivers, you can download them free here
If you problem was solved, Kindly do Rate!
Jul 31, 2009 | Sony MEX-BT2500 CD Player
The mouse keeps getting erased from the Bluetooth Devices Menu
Try pairing again.
Or re-install the bluetooth driver.
Oct 21, 2005 | EPoX BT-MS02B Mouse
2,789 people viewed this tip
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
