Tip & How-To about Dishwashers
What to do if your dish washer does not drain.
Everyone expects their dishwasher will work correctly. They can become nonchalant about it until one day it does not function. Sometimes the dishwasher doesn't drain as expected. Most people immediately call the plumber when their dishwasher doesn't work. There are several things you can try at home before having to pay an expensive service fee.
1 Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher.It is amazing the problems children could accidentally cause, that are easy fixes.
2 Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dish washer to drain.
3 Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
4 Attempt to declog the line. Disconnect the hose from under your sink and see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
5 Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
6 Calla plumber. If the dishwasher is still not draining, the problems are a little more complex to fix. It is advisable to call plumber to make your dishwasher drain.
Good luck.
Dishwashers Logo
not draining
Instructions And what
You Need
  • Basic Tools,Rags
  1. Check the basics. Make sure that the dishwasher has actually finish the cycle. Your dishwasher will not drain until the end of the cycle. Many things may have interrupted the cycle. Check circuit breaker and reset it if appropriate. Also check the fuse. It is possible that you could have tripped a circuit have way through the cycle. Make sure the door is properly closed. Ensure you have chosen a cycle on the dishwasher. It is amazing the problems children could accidentally cause, that are easy fixes.
  2. Remove any excess food at the bottom of the dishwasher. The best way to do this is with your hands. Large food particles can block from going into the drain.This is also another extremely easy fix to make your dishwasher to drain.
  3. Check to ensure that the hoses are still attached. Use your manual to find where the hoses are. If they are not attached the owner's manual will give you instructions on how the attach the hoses to your specific dishwasher.
  4. Attempt to declog the line. Disconnect the hose from under your sink and check to see if there are any clogs. Use a hanger or towels, remove the clog from the hose.
  5. Remove the dishwasher basket. Again refer to your owner's manual for specific instructions.Normally you will remove it with a screwdriver. Make sure to work slowly. As you take the basket apart, you will be able to see if it needs to be cleaned. If there is dirt or debris, you can clean the parts with a rag or paper towel. After cleaning these parts, you can replace the basket.
Good luck.
Jan 30, 2011 | Frigidaire Dishwashers
water remain after a wash
You Need
  • Basic Tools,Rags
Good luck.
Dec 26, 2010 | Asko 1375 Dishwasher
glc4100 water fills but does not drain
You Need
  • Basic Tools,Rags
Good luck.
Dec 26, 2010 | GE GLC4100NWW Dishwasher
clogged drain
You Need
  • Basic Tools,Rags
Thanks for visit.
Dec 26, 2010 | Dishwashers
The dishwasher will not drain at the end of the cycle. I see by other complaints that this is a common problem.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  • Basic Tools,Rags
Hope this help?.
Good Luck and thanks for using fixya
Dec 15, 2010 | Dishwashers
311 people viewed this tip
Top Dishwashers Experts
Owen Barnes
