Tip & How-To about Plumbing
How to locate leaks on a toilet
One of the major sources of water loss is due to a leaky flapper valve on toilet. Even with a small leak you can increase your water bills twenty to thirty dollars a month. And if you have several toliets some will be used more than others. The ones that are used the least often leak the most. The easiest ways I've found to locate leaks is to use common food coloring. Use any color you like,I prefer the darker ones as they show up better to me.Remove lid from toilet tank being careful as they are made of china and will break or crack if handled roughly. Put about ten -twelve drops of food coloring directly into tank. Check in about one-two hours. If flapper is leaking the water in the bowl will be discolored.
Most flappers can be easily changed by home owner,some may
require help. If you feel comfortable doing this the first thing I would do is try to identify type you need for replacement.Repair parts are available in plumbing dept. of most stores carrying hardware.I like to have repair parts on hand if possible. Shut off water supply to toilet. Remove old flapper and install new one.
There are many different types so you may have to remove it to get the right one. If water won't shut off or you can't find replacement parts you proably should call a service co.If it is leaking very bad or you have more than one a service call will probably pay for itself in a couple months.Thanks.
Plumbing Logo
how to fix a leaky toilet
    1. Turn off the water at the shutoff valve, flush the toilet and hold down the handle. There may be a little water left in the bottom of the tank, but don't worry about it. Wipe the flapper seat with a clean cloth to make sure it's free of debris, and check it for cracks or splits (Image 1).
      How to Fix a Leaking Toilet ' how-tos ' DIY
      www.diynetwork.com/how-to/.../how-to-fix-a-leaking-toilet DIY Network
    Feedback
  1. How to Fix a Leaky or Runny Toilet - This Old House
    www.thisoldhouse.com > ... > Toilets
    This Old HouseA toilet that leaks or runs is an easy homeowner fix-if you know how to diagnose the trouble. ID parts and problems with this handy guide, and hit the hardware ...
Dec 26, 2015 | American Standard Home
the toilet runs water for about 15 seconds at least once each hour during the day when not even in use, what needs to be adjusted or fixed?
Sounds like you have a leaky "flapper valve". The replacements are cheap and readily available at any home improvement store. Get the make of toilet, and take it with you. The valves are easy to replace and are pretty standard.
Oct 12, 2014 | Home
How much water can leak from a toilet inlet valve
Make sure the flapper seals properly. If not the tank empties out into the bowl slowly, the the refill valve allows more water into tank. Then it leaks out and cycle is repeated If the refill valve does not close properly the tank will continue to fill - you will always hear it - and the excess goes down the overflow and is wasted. Unless you have money to burn you should not contact a plumber. The replacement of these parts is a simple operation and you can get these parts at any home depot store.
Sep 08, 2017 | Home
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
My toilet keeps leaking from tank to bowl--replaced all internal parts
If the flapper and all has been replaced. then it must be worn out where the flapper sits. or its not smooth.check to make sure it is smooth where the flapper closes, and make sure it closes fully when flushed. you might be better off with a new toilet, but thats up to you!
Mar 11, 2014 | American Standard Colony 2388.012.222...
455 people viewed this tip
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
