Tip & How-To about Clothing Accessories
Purchasing sunglasses for square faces
The square facial type has a sharp jaw-line and a broad forehead. Similar to diamond facial type, the height and width of the face are often the same distance. Modern circular metal frames look very good as they compliment the face by adding the round edges that are sometimes missing.
Clothing Accessories Logo
How could I know which sunglass suites me?
Well, here are some advices on how to match your sunglass to your face: 1. Suare face: Most complimentary style of sunglasses for a square face: To minimize the width of the face, it is best to choose sunglasses that add length. This can be best achieved by buying sunglasses that are not as wide as the widest part of your face. It is also a good idea to soften the "squareness" of a face by more fluid, rounded style frames, so as to decrease the perception of a broad jaw line. 2.Oval face-Most complimentary style of sunglasses for an oval shaped face: Generally any type of sunglasses suits an oval face, but just make sure that the size of the frame is proportionate to the face. 3.Round face: Most complimentary style of sunglasses for round shaped face: To sharpen a round face, select frames with straight or angular lines that will help make the face look thinner and longer.
4.Diamond face:Most complimentary style of sunglasses for a diamond shape face: Glasses that are oval, shaped or rimless are very complimentary for this type of face.
5. Rectagle face-Most complimentary style of sunglasses for squar shaped face: To compliment this style of face, it is best to choose sunglasses that will shorten the face and widen the face, both at the same time. The best style of frame to choose is one that is round, or deep to help soften the face.
6.Triangle face-Most complimentary style of sunglasses for a Base-Down Triangle face: To compliment this style of face, it is best to emphasis the top part of your face with strong balancing frames. 7.Inverted triangle-Most complimentary style of sunglasses for an inverted triangle face: Choose a type of frame that balances your face and broadens the lower part of your face. Low temples and rimless style of sunglasses are a good style to consider.
Nov 07, 2010 | Clothing Accessories
What kind of sunglass frame should I choose for my square face?
If you have an equally strong forehead and jaw line that match the sides of your face you have a square face.
The very best frame shape for you is an oval or round shape that will help soften and minimize your jaw line. Look for larger oval or round frames if you have a larger face, and smaller frames if your face is smaller.
Some great frames for your face type include the Dragon Spree, Coach Lindsay, Julbo Colorado and Drus, and the Ralph Lauren 876/S. You should be able to find just the right frame to fit your face and your budget!
405 people viewed this tip
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
