Tip & How-To about Epson DFX-9000 Matrix Printer
EPSON Impact Printers on a Mac
Connection Type : USB or TCP/IP
Driver : EPSON 9-pin or 24-pin Series 1.3
(resident CUPS / PPD driver - provided by Apple)
(no official EPSON driver)
>USB direct connection - check System Profiler-> under USB connection
>Got to Print & Fax and add the printer using the above driver
>TCP/IP connection - LAN set-up for printer configuration
>download EPSONNet Config Utility from http://support.epson.com
>run app and it will locate the printer regardless of IP address
>config to taste - default user/pass (it's blank, just hit OK button)
*the EPSONNet Config Utility is also available for Windows
(it's a neat utility)
Epson DFX-9000 Matrix Printer Logo
I need a driver for my Dell 3010cn for my Mac OS X.
Here is how to use the Dell 3010cn Color Laser Printer on Mac OS 10.6 Snow Leopard (or 10.3-10.5):
1) Install Ghostscript 8.64
http://www.openprinting.org/download...-8.64so-ub.dmg
2) Install Foomatic-RIP-4.0.2
http://www.openprinting.org/download...-4.0.2.211.dmg
3) Download the PPD
OpenPrinting database - Printer: Dell 3010cn
4) Add printer using USB or IP address (LPD or IPP protocol). Change driver from Autoselect/Generic to other, and find the PPD from 3).
how should I open my WeP Dotmatrix printer top panel to change the board
Sir/Madam
You Need To Go Below URL Link and download Some file To Fix your Epson Printer Problem,I Hope after Download file and follow instruction metion on the URL Link Site You able To Fix Your Epson Printer problem :
SOLUTION
  1. Download the attached file(s). You will probably just need the 24-pin PPD, but I have also included the 9-pin PPD (which I haven't tested) just in case.
  2. Browse to the CUPS web interface at http: // localhost:631
    NOTE: The printer installer system from the GUI will NOT work. It will throw an error and promptly fail
  3. Create the printer listing using the CUPS web interface, and when it asks for a PPD, point it at the one you just downloaded
  4. PROFIT!!
I hope this helps someone, ANYONE who has been in the same straits I have been.
So man your chips, and may The Source be with you!
Thread Working with WIPRO WeP and Epson dot matrix printers
Or
You Still having Brother Printer Problem then Follow Us On:
Epson Printer Support
how can i install canon pixma ip1980 for ubuntu 10.10
1) Download and install this: http://www.ziddu.com/downloadlink/2820548/driver_iP1880.zip
You can just extract the file and double click on the .deb file.
2) Open System ? Administration ? Printing ? New Printer, to Select Connection chose Canon ip1800 series USB #1
3) in Printer driver chose: Provide PPD file
4) point that at: /usr/share/cups/model/canonip1800.ppd
5) Give the name of ip1880/ip1700/ip1980 ? Apply
6) Restart the computer
7) open the terminal and write: cd /usr/lib After that, press Enter
8) write in terminal: sudo ln -s ./libtiff.so.4.2.1 ./libtiff.so.3 press Enter
9) Now it should work
gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
my LQ 300+ is not compatible with my windows vista
More comprehensive information to those who are looking to use the Epson LQ-300+ with Ubuntu.
You can download the ppd from http://www.cups.org/ppd/epson/en/eplq300.ppd.gz
I just copied the .gz (don't extract the ppd) file to /usr/share/foomatic/db/source/PPD/Epson/
(not sure where else I can put it).
Goto System->Administration->Printing and add a new printer. I have connected the printer with one of those cheap USB to Parallel cables. The printer is detected as EPSON LQ-300+
Select driver under Epson and you should see it listed as LQ-300+ 24 pin.
CAUTION!: The max resolution you can use under "Printer Options" is 360x180dpi. DO NOT select the highest 360dpi setting - your printer will go crazy and eat-up all your paper.
It works for me. I hope it works for you too.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
