Tip & How-To about Car Audio & Video
How to enter a Ford Radio Code
To enter the security code and get your radio up and running again follow these instructions;
Turn the radio on and the display will show ' CODE - - - -
Press preset button [ 1 ] repeatedly to get the first digit on the display
Press preset button [ 2 ] repeatedly for the second digit
Press preset button [ 3 ] repeatedly for the third digit
Press preset button [ 4 ] repeatedly for the fourth digit
To enter the code press the [ 5 ] key to accept.
The set should now operate.
If you have lost the code to your radio
Remove the radio from the dash and find the serial number of the radio which is on a label on the case.
For European Ford Radios you can get your code here for £3.50 using the serial number of the radio.
I have used this site numerous times and can confidently recommend the service as fast and accurate. This site is for European Fords only.
Ford dealerships charge over £20 for this so there is a considerable saving in using this service.
For USA Fords you will need to contact your local Ford Dealership with the VIN number of your car. Expect to pay $30 - $50.
Hope this Tip helps. Please do leave a vote for it. Many Thanks.
Car Audio & Video Logo
What buttons do you hold to unlock stereo for 2001 audi Ty
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi Concert radio from the car manufacturer, or from an Audi dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for a 2002 Audi TT Concert radio is:
1. Simultaneously push "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then simultaneously push again "SCAN" and "RDS" keys to confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready to use!
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
Oct 14, 2011 | 2001 Audi TT
radio locked no code
Unlocking the Delco Radio Theft-Deterrent Feature After a Power Loss
If you know the code that was used to lock the radio then use the following instructions from the owner's manual to unlock the radio.
Quote:
Enter your secret code as follows; pause no more than 15 seconds between steps:
1. Turn the ignition on. LOC will appear on the display.
2. Press MIN and 000 will appear on the display.
3. Press MIN again until the last two digits agree with your code.
4. Press HR until the first one or two digits agree with your code.
5. Press AM-FM after you have confirmed that the code matches your secret code. The display will show SEC, indicating the radio is now operable and secure.
If you enter the wrong code eight times, INOP will appear on the display. You will have to wait an hour with the ignition on before you can try again. When you try again, you will only have three more chances (eight tries per chance) to enter the correct code before INOP appears.
If you don't know the code that was used to lock the radio then you will have to use the dealer's unlock procedure as follows. The dealer code changes over time - the one listed is current as of this posting. If it doesn't work try 08359 or search the forum for messages with a more recent code.
Quote:
1. Press and hold presets 2 & 3 for about 10 seconds until the first three digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM-FM button, write down the next three numbers.
4. Call 1-800-537-5140. When asked, enter dealer code 202108, press the * button, and enter the six digit code from the radio. You will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first two numbers, press the MIN button and set the next two numbers, then press the AM-FM button. The display will show SEC, indicating the radio is now operable and secure.
To remove the code, repeat step 5. you should see --- on the radio face indicating the code is now out of the radio."
Dec 29, 2010 | 2000 GMC Jimmy
2000 Chevrolet Lumina Unlock radio code
If you have the security code it's easy. The code is something that either you or a previous owner entered. If you don't have the security code a trip to the dealer will be in your future.
Unlocking the Theft-Deterrent Feature After a Power Loss
Enter the code as follows; pause no more than 15 seconds between steps.
  1. Turn ON the ignition. LOC will appear on the display.
  2. Press MN and 000 will appear on the display.
  3. Press MN again to make the last two digits agree with your code.
  4. Press HR to make the first one or two digits agree with your code.
  5. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is now operable and secure.
Entering the incorrect code eight times will cause INOP to appear on the display. Wait an hour with the ignition in the ON position before you try again. When you try again, you will have three more chances (eight tries per chance) to enter the correct code before INOP appears.
Deactivating the Theft-Deterrent Feature
  1. Turn the ignition to ACC or ON.
  2. Turn OFF the radio.
  3. Press the 1 and 4 buttons together. Hold them down until SEC shows on the display.
  4. Press MN and 000 will appear on the display.
  5. Press MN again to make the last two digits agree with your code.
  6. Press HR to make the first one or two digits agree with your code.
  7. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show -- -- --, indicating that the radio is no longer secured.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered.
Dec 27, 2010 | 2000 Chevrolet Lumina
I have the unlock code for my 99 saturn sl2 but i need the radio layout
Hello, you will need to enter your radio unlock code using these instructions.
  1. Press SEEK DOWN, SEEK UP, TUNE DOWN, or TUNE UP. The radio display should show 0000.
  2. PRESS SEEK DOWN to set the first digit.
  3. Press SEEK UP to set the second digit.
  4. Press TUNE DOWN to set the third digit.
  5. Press TUNE UP to set the fourth digit.
  6. If the code was entered correctly, the radio will display SEC (SECURE). The theft deterrent system for the radio is now active and normal operation may be resumed. If the code was entered incorrectly, the radio will display Err for 5 seconds and the LOC (LOCKED) will be displayed again. If LOC is displayed, repeat 1-6.
  7. If the correct code is not entered in 8 attempts, follow the next steps:
  8. 7.1. Turn ignition to ACC position. 7.2. Turn radio power switch OFF. 7.3. Wait one hour before repeating steps 1 through 7. If attempts to unlock the system are made before the one hour period is up, the radio will display INOP (INOPERATIVE). Continue to wait. If the ignition is not in the ACC position, power will never reset internally to allow itself to be unlocked. 7.4. After one hour, repeat steps 1-7.
Jul 03, 2010 | 1999 Saturn SL
malibu 2001 radio locked
hi friend,
Deactivating the Theft-Deterrent Feature Enter the code as follows; pause no more than 15 seconds between steps.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered. When battery power is removed and later applied to a secured radio, the radio will not turn on and LOC appears on the display. To unlock a secured radio, refer to "Unlocking the Theft-Deterrent Feature After a Power Loss".
hope this helps u
please rate me..............
thank u for using fixya
regards
sivvaranjini
Nov 26, 2009 | 2001 Chevrolet Malibu
599 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
